My admin access on https://home.myopenhab.org is blocked.
I can only log in as an end user – the Main UI only shows “Floorplan” and “About & Help”.
Therefore, I have no access to the admin settings or the Cloud Connector.
My admin email: nh@cumlosen.de>
I have a backup admin token.
Raspberry Pi 3 - openHAB 4.3.0
Could you please reactivate my admin access or provide instructions on how to restore admin access?
It’s not clear specifically what you are talking about. There are two sets of users involved here.
https://home.myopenhab.org takes you straight to your openHAB instance. You manage the users and roles for your openHAB instance, not the cloud server. You set up a user with an admin role when you first set up OH and that’s the user being asked for when you click on the shield with the lock icon at the bottom left of MainUI.
These users are completely separate and independent of the users you use to log into the cloud server (i.e. when you go to https://home.myopenhab.org and it asks for a username and password before it shows you your MainUI page). This only authenticates you to the cloud server, not to your openHAB instance.
To get to the admin parts of MainUI through the cloud server, you have to log in twice using two different users/passwords. First you need to authenticate to the cloud server to get access to your openHAB instance in the first place. Then you need to authenticate to your openHAB instance to assume the admin role.
