I’ve lost my habpanel Admin password (stupid me). I’m searching for ways to reset this, I still have access to the Linux PC itself, but cannot login into habpanel.
thx
Uwe
thx
Uwe
I am not aware of that there is a specific admin password for habpanel. So I think you are looking for the user/password of Main UI.
To reset Main UI admin password you can follow these steps:
thx Wolfgang … as I’ve physically access to my host (older notebook running on linux) I tried to use openhab-cli console within the terminal window – but command not found …
You mean the command openhab-cli was not found ?
Please tell us more about you openhab installation - is it installed by using apt command or was it installed in a different way ? Which OH version do you use ? Which linux distribution / version do you use ? It is not openhabian ?
you can even try to get manual karaf console login:
ssh openhab@localhost -p8101
habopen
iobroker@iobroker-HP-EliteBook-840-G3:~$ cat /etc/os-release
NAME=“Ubuntu”
VERSION=“20.04.4 LTS (Focal Fossa)”
ID=ubuntu
ID_LIKE=debian
if I’m not mistaken I installed it using the apt command.
independent what command I try to use, it’s always the same result
iobroker@iobroker-HP-EliteBook-840-G3:/$ openhab-cli info
openhab-cli: command not found
Check it with:
dpkg -l | grep openhab
Should result in something like:
ii openhab 3.3.0-1 all openhab
ii openhab-addons 3.3.0-1 all openhab-addons
If not it is not installed on that host - may be on an other …
in case openhab package is installed then openhab-cli should be there:
dpkg -L openhab | grep openhab-cli
which results in :
/usr/bin/openhab-cli
/etc/openhab-cli
/etc/openhab-cli/command-overrides.sh
first one is the command.
thx Wolfgang … it is really weird …
root@iobroker-HP-EliteBook-840-G3:~# dpkg -l | grep openhab
root@iobroker-HP-EliteBook-840-G3:~# dpkg -L openhab | grep openhab-cli
dpkg-query: package ‘openhab’ is not installed
but I can open it …
http://192.168.5.6:8082/habpanel/index.html#/
root@iobroker-HP-EliteBook-840-G3:~# ifconfig
enp0s31f6: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.5.6 netmask 255.255.255.0 broadcast 192.168.5.255
