Administrator of the zwave Database
Hello
some weeks ago i write a topic here, because my zuno dont work with OH2. The result was that i need a entry in the zwave database of OH2. Chris Jackson write that he would make one for my actual configuration. Because zuno is for development and you can make many configurations. But Chris did not answer my Mails now since 4 weeks. Who else has Administrator rights for the Database?
kind regards
Werner
You don’t need admin rights, you just need edit rights.
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-database-guide
Chris is on holidays, so please be patient and wait for his return.
I am registered there, but i have no add Button and can not add any Zwave Device
kind regards
Werner
Then you need to write an email with your username to Chris and ask for edit rights, like stated in the docs:
To use the database you must first register on the site, then email to have your access updated to allow you to edit the information.
Hello
i have send a email again. But since 5 weeks Chris did not answer. What can i do now? Is there another Administrator?
kind regards
Werner
Sorry - I’ve not received any email recently, so not sure where you are sending them? Also, sorry again, but I didn’t see this original message here as I was on holiday and got back last week.
Hello Chris
yes, i have checked my mails and they was send
last mail was this
Hello Chris
I read now many about zwave and the Database. Can you please give me the rights for add Devices?
So I can add my zuno and contue my development.
I see that there is a review first, so I think my configuration would be ok after then
Kind regards
Werner
and now?
kind regards
Werner
Sorry - what does this mean :confused:?
Hi Chris
3 days ago i write that i want to add my zuno to the Database, so it works then with openhab 2. I start writing you 6 weeks ago and give you Informations about the zuno and my problem
kind regrads
werner
As far as I know, you should have access already. Maybe it got removed (I had to revert to a backup due to a hard disk crash and lost around 1/2 day or data). I’ll check.
So according to the admin, you have access - i’m not sure what else to suggest. Have you actually logged in?
Hi Chris
now it works :slight_smile: I have now the Add Button. Before i was registered but i dont have the Add Button, so dont can import my zuno.
kind regards
Werner
I think there is already an entry for the uno so you might need to add channels manually into the database so that we build up a ‘superset’ of channels…
