Advice for best way to execute Scripts
Hello
I am trying to use the Synology-VM API to turn on / Shut down my virtual machine with the use of a openhab switch item.
In the past i implemented a python script which i put into the scripts folder.
I had to install python for this (i used it a while ago when i was runnint openhabian on a debian vm so i installed python there). Now i am running openhab in a docker container on my synology nas.
I did a little research and found different approaches.
Would you recommend setting up HABApp?
Should I install python in the openhab docker container or is there a more elegant way?
There is the documentation for the api so you know what i try to achieve:
Synology Virtual Machine Manager API Guide
Thank you for your support!
If you must use Python, then HabApp seems to be the way to go in terms of a currently supported solution.
Alternatively you could use jsscripting or jruby. There is no need to run external scripts. jsscripting / jruby is just as capable as any external scripting and can certainly deal with the synology api.
For example, you can find a synology api implementation in ruby: synowebapi | RubyGems.org | your community gem host
And in javascript: https://www.npmjs.com/package/synology-api
Or, since only want to perform a shutdown, you could write your own implementation using any of the available http interface in the respective language ecosystem.
