Hi forum
my situation:
- I’m an absolute beginner with home automation
- I decided to go for openHab as it seems more flexible and powerful in the long run
- I would like to start simple and easy but set up my base hardware to be scalable for more advanced things
My current approach:
- Fritzbox 7590 running
- ordered, not jet installed: FRITZ!Smart Thermo 302 and FRITZ!DECT 440
I want to use the Fritz components to do some very simple first steps inside the Fritz automation environment but also have something which seems to be easily integrated in Openhub
- Raspberry Pi 5 with openHabian (5.0.1) running
- Fritz Binding installed and the Fritzbox is configured as Thing and online
- Not figured out, if I can do anything more than that (Turn on/off Wifi, Gues Wlan or such things)
- RITZ!Smart Thermo 302 and FRITZ!DECT 440 connected
- First Items on Overview page created, can control the Set Temperature via App
Next step will be to connect the Fritz components into the current setup and try to learn what I can do with them solely staying inside the Fritz Environment and then move on to the openHab environment and play around.
Already some limitations I found:
- Can’t seem to set the ECO Temp or Comfort Temp via OpenHAB
After that I want to get going with some non Fritz components. Possible use cases I have in mind:
- Switch on/off sensors to detect open windows and shoot an alarm if a window stays open for to long during winter time
- Humidity/Temperature sensor placed in a room and connected to the control of a thermostat (maybe a non Fritz one)
- Lights I can turn on and off or change the color via openHab smartphone app
Now the questions, what is a good way to go these next steps? What “protocol” is in my situation advisable? Zigbee? Z-Wave?
My understanding is, that whatever I decide to choose, I will need some kind of gateway hardware probably in USB form to directly attach it to the Raspberry Pi.
My pain. There is so much choice and I’m totally lost on even how to decide what to choose. Is a Sonoff Zigbee 3.0 USB Dongle Plus suitable to get started but also be prepared for the future? Based on the price it seems rather high end. Is a Conbee II more suitable? Is the missing antenna maybe a problem to be future proof (I don’t want to have to set up repeaters and such.)
Depending on the protocol, what would be a good temperature/humidity sensor to start with?
I’m not on a tight budget, but I also don’t want to blindly go for pricey high end products and be totally over engineered. I would like to have some quick positive experiences with having accomplished something to stay motivated.
Also important to me is my privacy. Therefore I don’t want to use components which communicate “home”, rely on a cloud or things like this.
A most helpful answer for me probably would be for example:
- I started with $protocol, used $this $hardware. Had these experiences, came across the problems, stayed with the choice because, switched and got happy because
- If I would start now days I probably would start with $… because
