Dear All
I have problems with configuration of this device.
In manual:
Setting automatic report flags.
Parameter 101-103 [4 byte dec] can be configured through your gateway in case that the default settings of your meter are not what you desire.
In HABMIN
1 -> Battery Report 2 -> MultiSensor Report for the whole device 4 -> Meter Report for Watt for the whole device 8 -> Meter Report for kWh for the whole device 256 -> Meter Report for Watt for clamp 1 512 -> Meter Report for W
I want to have information from each clamp separately. (W, kWh, A, V)
Calculated value from manual is 4144911
What shuld I put to 101, 102 and 103 setting in Habmin?
Please help
I want to write my problems more clearly:
1 Description of parameters is incorrect in HABMin. Also it is not full (ended on letter “W”).
2 The most important - looks like open HABMIN cant set parameter 101 to such a big value as 4144911. I have no problems with smaller value, but i cant configure anything about Ampers reporting. Please help how to solve or may be another utility to set this value?
My device is DSB28 firmware 1.7.
Please help. Looks like configuration part in habmin is from G1, but this devices have different configuration parameters. Needed to fix it.
So how can I change it? If i change it on your site, how I can insert it to my habmin? I just created an account - NorthStar, but not shure that I understand that system well. I still cant run Habmin on my OH server because of windows server platform, so I use it very rarely only to configure zwave devices ((
I downloaded from the link https://openhab.ci.cloudbees.com/job/openHAB2-Bundles/
So I dont use any manager or script. I work on Windows
Can It be some Habmin restriction - that it cant work with values more than 65535?
