I can not set parameters or receive values from Clamp 3 on my AEON HEM Gen5 in habmin.
What i can find in documentation about HEM 2 parameter 7 was Threshold change in wattage to induce a automatic report (Clamp 3). (Valid values 0-60000).
In Habmin I do not have parameter 7 and i have no entries to connect items to read clamp 3 values.
2017-03-25 13:26:58.306 [WARN ] [class.ZWaveMultiInstanceCommandClass] - NODE 9: CommandClass NO_OPERATION (0x00) not implemented by endpoint 1, fallback to main node.
2017-03-25 13:26:58.375 [WARN ] [class.ZWaveMultiInstanceCommandClass] - NODE 9: CommandClass NO_OPERATION (0x00) not implemented by endpoint 2, fallback to main node.
2017-03-25 13:26:58.443 [WARN ] [class.ZWaveMultiInstanceCommandClass] - NODE 9: CommandClass NO_OPERATION (0x00) not implemented by endpoint 3, fallback to main node.
Does someone have AEON HEM Gen5 with 3 phases fully working in OpenHAB or can you recommend another system where i can gather the values and send it over to OpenHAB with mqtt.
Sorry - the XML I was after was the one that OH creates for your device - not the database entry…
Still, this does answer my question about what the device is (ZW095) so I’ve found it in the database and it does appear to be missing the parameter 7 and clamp 3, and the reset channel so these need to be added if someone fancies doing this?
Ignore the basic command class mapping - if it’s not used, then fine…
For security, yes, it’s supported. The table shows two configurations - classes that are supported when where in a non-secure network, and also when in a secure network - so the bottom right quadrant are the secure classes.
