Aeon labs smart energy switch debug
Anyone tell me why I keep seeing these log items for the aeon labs smart energy switch? It happens over and over and over…thanks!
16:04:53.327 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 0F 0E 32 02 21 74 00 00 00 00 00 0A 00 00 04 90 15
16:04:53.328 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 15: Application Command Request (ALIVE:DONE)
16:04:53.329 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Starting initialisation from DONE
16:04:53.330 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@17146ce already registered
16:04:53.330 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 15: Incoming command class METER
16:04:53.332 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 15: Received METER command V2
16:04:53.334 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 15: Meter: Type=Electric(1), Scale=kWh(0), Value=1.168
16:04:53.335 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
16:04:53.336 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveMeterValueEvent
16:04:53.337 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 1.168
16:04:53.338 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating channel state zwave:device:controller:node15:meter_kwh to 1.168 [DecimalType]
16:04:53.342 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_W <> E_KWh
16:04:53.342 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
16:04:53.343 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
16:04:53.344 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 0F 0E 32 02 21 74 00 00 00 00 00 0A 00 00 04 90 15
16:04:53.345 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 14 00 04 00 0F 0E 32 02 21 74 00 00 00 00 00 0A 00 00 04 90 15
16:04:53.347 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0F 0E 32 02 21 74 00 00 00 00 00 0A 00 00 04 90
some other weird messages from this one:
16:34:22.913 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 15: Application Command Request (ALIVE:DONE)
16:34:22.915 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Starting initialisation from DONE
16:34:22.916 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@17146ce already registered
16:34:22.917 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 15: Incoming command class COLOR
16:34:22.918 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 15: Received COMMAND_CLASS_SWITCH_COLOR V0
16:34:22.919 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 15: Process SWITCH_COLOR_SUPPORTED_REPORT
16:34:22.921 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 15: Color Supported = Warm White(0)
16:34:22.923 [DEBUG] [.commandclass.ZWaveColorCommandClass] - NODE 15: Color Supported = Amber(5)
16:34:22.925 [WARN ] [.commandclass.ZWaveColorCommandClass] - NODE 15: Invalid color 10
16:34:22.928 [WARN ] [.commandclass.ZWaveColorCommandClass] - NODE 15: Invalid color 13
16:34:22.930 [WARN ] [.commandclass.ZWaveColorCommandClass] - NODE 15: Invalid color 14
16:34:22.932 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveColorValueEvent
even weirder, they work…but i see for these smart energy switches it says they are dead
16:52:35.257 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘GuestRoom_PowerStrip’ received command OFF
16:52:35.264 [INFO ] [marthome.event.ItemStateChangedEvent] - GuestRoom_PowerStrip changed from ON to OFF
16:52:35.623 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
16:52:35.624 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
16:52:35.625 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
16:52:35.626 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
16:52:35.627 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
16:52:35.627 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 20: Sent Data successfully placed on stack.
16:52:35.728 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 8: No more messages, go back to sleep
16:52:35.728 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 8: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
16:52:35.729 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
16:52:37.858 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 4B 01 01 03 A3
16:52:37.859 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
16:52:37.861 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 4B 01 01 03 00 00 AD
16:52:37.863 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 4B 01 01 03 00 00 AD
16:52:37.866 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=4B 01 01 03
16:52:37.868 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 20: SendData Request. CallBack ID = 75, Status = Transmission complete, no ACK received(1)
16:52:37.870 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 20: Node is DEAD. Dropping message.
16:52:37.871 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEv
Because this is an energy switch, and it’s sending periodic energy reports.
What is weird about it - can you give us some context as it looks ok to me.
The context is im just debugging lots of nodes and noticed it; its a smart energy switch so i would assume colors have nothing to do with that; that’d be more like a rgb bulb to me. I have noticed since i put the Dec21 build of OH2 on that the Smart Energy switches i have report dead alot. Though they still work and I can control them.
Aeon and I think Fibaro switches have colour leds around the edge and you can change the colour with the colour class. I don’t know the device, but maybe that explains it?
Thanks…never knew you could change that…seems pretty useless since it sits on the ground behind furniture.
LOL
Yes, if the switch is hidden behind furniture it isn’t very useful. Normally, the color is supposed to be an indicator of how much power is being used by the appliance. You’d have to check the docs to see what the exact colors mean. There’s also a night light mode, the LED can be kept off, or you can set it to whatever color you like.
I really like the energy meter features of the Smart Switch, once I get around to it I’m going to use it to notify me when the washing machine finishes it’s cycle because I can’t normally hear the buzzer. There’s a whole thread about using an energy monitoring system to track a washing machine. It could certainly be used to track other appliances as well.
