2016-01-31 13:13:43.877 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class ZWAVE_PLUS_INFO
2016-01-31 13:13:43.878 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class DEVICE_RESET_LOCALLY
2016-01-31 13:13:43.878 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class ASSOCIATION_GROUP_INFO
2016-01-31 13:13:43.879 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class POWERLEVEL
2016-01-31 13:13:43.880 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class MULTI_INSTANCE_ASSOCIATION
2016-01-31 13:13:43.880 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class SECURITY
2016-01-31 13:13:43.880 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class FIRMWARE_UPDATE_MD
2016-01-31 13:13:44.744 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@54d5a758, ignoring.
2016-01-31 13:13:44.782 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@526ddc1f, ignoring.
2016-01-31 13:13:44.822 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@6ae7f3d6, ignoring.
2016-01-31 13:13:44.861 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@7e0e12b, ignoring.
2016-01-31 13:13:44.903 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@4ae934fc, ignoring.
2016-01-31 13:13:44.955 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@7b9bc738, ignoring.
2016-01-31 13:13:45.002 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@4f487777, ignoring.
2016-01-31 13:13:45.039 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@514c35f, ignoring.
2016-01-31 13:13:45.078 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@6a2b4cdc, ignoring.
2016-01-31 13:13:45.115 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@723d9c4f, ignoring.
2016-01-31 13:13:45.152 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@7b4d8b3, ignoring.
2016-01-31 13:13:45.188 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@4d291a61, ignoring.
2016-01-31 13:13:45.225 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@12377b9e, ignoring.
2016-01-31 13:13:45.322 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 0, ignoring.
2016-01-31 13:13:45.355 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 255, ignoring.
2016-01-31 13:13:45.389 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 0, ignoring.
2016-01-31 13:13:45.422 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = BATTERY, value = 100, ignoring.
2016-01-31 13:13:50.426 [ERROR] [WaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 2 attempts left!
2016-01-31 13:13:50.465 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class ZWAVE_PLUS_INFO
2016-01-31 13:13:50.466 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class DEVICE_RESET_LOCALLY
2016-01-31 13:13:50.466 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class ASSOCIATION_GROUP_INFO
2016-01-31 13:13:50.466 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class POWERLEVEL
2016-01-31 13:13:50.467 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class MULTI_INSTANCE_ASSOCIATION
2016-01-31 13:13:50.467 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class SECURITY
2016-01-31 13:13:50.467 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class FIRMWARE_UPDATE_MD
2016-01-31 13:13:55.468 [ERROR] [WaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 1 attempts left!
2016-01-31 13:13:55.508 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class ZWAVE_PLUS_INFO
2016-01-31 13:13:55.508 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class DEVICE_RESET_LOCALLY
2016-01-31 13:13:55.509 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class ASSOCIATION_GROUP_INFO
2016-01-31 13:13:55.509 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class POWERLEVEL
2016-01-31 13:13:55.509 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class MULTI_INSTANCE_ASSOCIATION
2016-01-31 13:13:55.510 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class SECURITY
2016-01-31 13:13:55.510 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class FIRMWARE_UPDATE_MD
I got this debug data from my command line. It looks like everything works and it just rejects the z-wave plus data.
So I think my problem is solved after all.
