@ptmuldoon, what did you add it as? A standard Dimmer, or a true Color item?
I am current to the 2.0 Beta build, but Color is not working for me.
I have 4 Aeon ZW098 LED Bulbs in my configuration, but cannot control them as color items, only as a Dimmer. I see the Aeon bulb listed in the Paper Thing bindings list, however I cannot manually add them. Which could be my problem.
The following works to use them as White Dimmer bulbs.
Dimmer Bulb_Kitchen "Kitchen Light" <light> (Kitchen_Lights,gBedtime,gLights) { zwave="7:command=SWITCH_MULTILEVEL,respond_to_basic=true" }
I’ve tried without the command, which seems to make the bulb less happy, complaining about no preferred command class, yada yada.
Does anybody have ITEM or RULES they would share if these bulbs are now fully supported in OH2 (which I doubt)? There are just not a lot of info on how to configure these.
When switching to a COLOR item, I get the following errors.
08:28:37.638 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bulb_Kitchen' received command 0.0,0.0,100.0
08:28:37.639 [WARN ] [erter.ZWaveMultiLevelSwitchConverter] - NODE 7: No converter found for item = Bulb_Kitchen, endpoint = 0, ignoring command.
08:28:39.259 [WARN ] [erter.ZWaveMultiLevelSwitchConverter] - NODE 7: No converter found for item = Bulb_Kitchen, endpoint = 0, ignoring command.
08:28:39.259 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Bulb_Kitchen' received command 332.0,100.0,100.0
08:28:39.274 [INFO ] [ome.event.GroupItemStateChangedEvent] - Kitchen_Lights changed from 0.0,0.0,100.0 to 332.0,100.0,100.0 through Bulb_Kitchen
08:28:39.279 [INFO ] [marthome.event.ItemStateChangedEvent] - Bulb_Kitchen changed from 0.0,0.0,100.0 to 332.0,100.0,100.0
