I use this, maybe to compley and anyone can make it more easy.
Is also covers a replay of the same command. I see that if the wall mount is far away from z-wave stick, the command received more times.
Sorry for the german namings and comments.
Items:
// Funkschalter 01
// Z-Wave me WALLC-S
Number WallSwitch01_Scene "Wandschalter [%.1f °C]" <temperature> (gMAPDB) { channel="zwave:device:xxxx:node26:scene_number" }
Switch swFunktaster1_Taste1_Klick (gMAPDB)
String stFunktaster1_Taste1_Klick_Helper (gMAPDB)
DateTime dtFunktaster1_LastUpdate "Funktaster1_LastUpdate [%1$tH:%1$tM]" (gMAPDB)
DateTime dtFunktaster1_LangKlick_LastUpdate "Funktaster1_Langklick_LastUpdate [%1$tH:%1$tM]" (gMAPDB)
String swFunktaster1_OldState "Funktaster1_OldState [%s]" (gMAPDB)
Switch swFunktaster1_Taste1_Doppelklick (gMAPDB)
Switch swFunktaster1_Taste1_Langklick (gMAPDB)
Switch swFunktaster1_Taste2_Klick (gMAPDB)
Switch swFunktaster1_Taste2_Doppelklick (gMAPDB)
Switch swFunktaster1_Taste2_Langklick (gMAPDB)
Switch swFunktaster1_Taste3_Klick (gMAPDB)
Switch swFunktaster1_Taste3_Doppelklick (gMAPDB)
Switch swFunktaster1_Taste3_Langklick (gMAPDB)
Switch swFunktaster1_Taste4_Klick (gMAPDB)
Switch swFunktaster1_Taste4_Doppelklick (gMAPDB)
Switch swFunktaster1_Taste4_Langklick (gMAPDB)
The rule changes the above switch items. They can be used to trigger rules regarding the needed scene.
rule "Z-Wave WALLC-S 01 events changed"
Item WallSwitch01_Scene changed
// Der Taste wird gerade lang gedrückt und wurde noch nicht losgelassen
if(WallSwitch01_Scene.state.toString == "1.2" || WallSwitch01_Scene.state.toString == "2.2" || WallSwitch01_Scene.state.toString == "5.2" || WallSwitch01_Scene.state.toString == "4.2")
// Zeit des Drückens merken
dtFunktaster1_LangKlick_LastUpdate.postUpdate(new DateTimeType)
return;
// Der Taster wurde nach einem Langklick wieder losgelassen
if(WallSwitch01_Scene.state.toString == "1.1" || WallSwitch01_Scene.state.toString == "2.1" || WallSwitch01_Scene.state.toString == "5.1" || WallSwitch01_Scene.state.toString == "4.1")
// Ist der Unterschied kleiner als diese Zeit, dann nur als Shortklick interpretieren
// und ein Statusupdate mit .0 schicken
// Hier wird die Zeit für Langklick eingestellt, ist diese unterschritten, ist es nur ein Shortklick
val long current_state = now.millis
val long previous_state = (dtFunktaster1_LangKlick_LastUpdate.state as DateTimeType).getZonedDateTime.toInstant.toEpochMilli
//logInfo("Logger", "portable switch 01 - Status: " + WallSwitch01_Scene.state.toString.mid(0,2) + "0")
if((current_state - previous_state) < 500)
WallSwitch01_Scene.postUpdate(WallSwitch01_Scene.state.toString.mid(0,2) + "0")
logInfo("Logger", "portable switch 01 - lange gedrueckt als kurz gedruckt veraendert")
return;
if (WallSwitch01_Scene.state.toString == "1.1")
// Dieses Kommando wird jede sec. so oft gesendet, bis die Taste wieder losgelassen wird
// kann dadurch zum dimmen benutzt werden
logInfo("Logger","portable switch 01 - Taste 1 lange gedrueckt")
if(swFunktaster1_Taste1_Langklick.state != ON)
swFunktaster1_Taste1_Langklick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste1_Langklick.postUpdate(OFF)
else if (WallSwitch01_Scene.state.toString == "2.1")
logInfo("Logger","portable switch 01 - Taste 2 lange gedrueckt")
if(swFunktaster1_Taste2_Langklick.state != ON)
swFunktaster1_Taste2_Langklick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste2_Langklick.postUpdate(OFF)
else if (WallSwitch01_Scene.state.toString == "5.1")
// kann dadurch zum dimmen benutzt werden aber nicht zum kippen eines Schaltzustandes, da dieser permanent kippt
logInfo("Logger","portable switch 01 - Taste 3 lange gedrueckt")
if(swFunktaster1_Taste3_Langklick.state != ON)
swFunktaster1_Taste3_Langklick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste3_Langklick.postUpdate(OFF)
else if (WallSwitch01_Scene.state.toString == "4.1")
logInfo("Logger","portable switch 01 - Taste 4 lange gedrueckt")
if(swFunktaster1_Taste4_Langklick.state != ON)
swFunktaster1_Taste4_Langklick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste4_Langklick.postUpdate(OFF)
rule "Z-Wave WALLC-S 01 events update"
Item WallSwitch01_Scene received update
// Falls es einen Reboot gab, diese Aktion nicht ausführen, da diese nicht gewollt ist
if(swAfterReboot.state == ON)
return;
// Taster 1: 1.0, 1.1, 1.2, 3.0, 3.1, 3.2
// Tester 2: 2.0, 2.1, 2.2, 6.0, 6.1, 6.2
// Taster 3: 5.0, 5.1, 5.2, 7.0, 7.1, 7.2
// Taster 4: 4.0, 4.1, 4.2, 8.0, 8.1, 8.2
//logInfo("Logger","Scene Update received " + WallSwitch01_Scene.state.toString)
// Caluclate now and last time of the item is updates as milli sec.
val long previous_state = (dtFunktaster1_LastUpdate.state as DateTimeType).getZonedDateTime.toInstant.toEpochMilli
// if prev status equal new status
// check if update is more then 1 sec. from previous update
if(WallSwitch01_Scene.state.toString == swFunktaster1_OldState.state.toString)
if((current_state - previous_state) < 1500)
return;
// remember new time of update and old state
dtFunktaster1_LastUpdate.postUpdate(new DateTimeType)
swFunktaster1_OldState.postUpdate(WallSwitch01_Scene.state.toString)
// Taste1
if(WallSwitch01_Scene.state.toString == "1.0")
logInfo("Logger","portable switch 01 - Taste 1 gedrueckt")
swFunktaster1_Taste1_Klick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste1_Klick.postUpdate(OFF)
else if (WallSwitch01_Scene.state.toString == "3.0")
logInfo("Logger","portable switch 01 - Taste 1 doppelklick")
swFunktaster1_Taste1_Doppelklick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste1_Doppelklick.postUpdate(OFF)
// Taste2
else if(WallSwitch01_Scene.state.toString == "2.0")
logInfo("Logger","portable switch 01 - Taste 2 gedrueckt")
swFunktaster1_Taste2_Klick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste2_Klick.postUpdate(OFF)
else if (WallSwitch01_Scene.state.toString == "6.0")
logInfo("Logger","portable switch 01 - Taste 2 doppelklick")
swFunktaster1_Taste2_Doppelklick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste2_Doppelklick.postUpdate(OFF)
// Taste3
else if(WallSwitch01_Scene.state.toString == "5.0")
logInfo("Logger","portable switch 01 - Taste 3 gedrueckt")
swFunktaster1_Taste3_Klick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste3_Klick.postUpdate(OFF)
else if (WallSwitch01_Scene.state.toString == "7.0")
logInfo("Logger","portable switch 01 - Taste 3 doppelklick")
swFunktaster1_Taste3_Doppelklick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste3_Doppelklick.postUpdate(OFF)
// Taste4
else if(WallSwitch01_Scene.state.toString == "4.0")
logInfo("Logger","portable switch 01 - Taste 4 gedrueckt")
swFunktaster1_Taste4_Klick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste4_Klick.postUpdate(OFF)
else if (WallSwitch01_Scene.state.toString == "8.0")
logInfo("Logger","portable switch 01 - Taste 4 doppelklick")
swFunktaster1_Taste4_Doppelklick.postUpdate(ON)
Thread::sleep(100)
swFunktaster1_Taste4_Doppelklick.postUpdate(OFF)
