I bought the Aeotec 6-in-1 (ZW100) sensor and noticed some oddities. I wonder if others have the same experience and if there’s something that can be done to improve it?
- Configurations from 48 to 64 (limits) are missing in Habmin / Paper UI
- After trying to change Temperature Threshold (41), the change is now always pending in HABmin. Other changes are going through normally.
- Thresholds don’t seem to work. I have Selective Reporting (40) enabled and for example Luminance Threshold (43) set to 5, but I’m still getting updates when the difference is only 1 LUX.
- “AlarmBurglar” which is the vibration sensor triggers whenever the PIR sensor does. However, vibration sensor can be triggered without triggering PIR sensor.
According to Habmin my sensor has firmware 1.8. It is running on USB power.
