parag
(parag)
October 11, 2015, 2:58pm
1
using
Aeotec z stick gen 5, door sensor, openhab , habmin
door status always shows closed
curl http://localhost:80t/items/Door_Motion/state
always give
CLOSED
item file -
cat /usr/share/openhab/configurations/items/default.items
Contact Door_Motion “Window [%s]” (DollHouse) {zwave=“2:command=SENSOR_BINARY,refesh_interval=1,respond_to_basic=true”}
openhab.cfg has following configuration for z wave binding
zwave:port=/dev/ttyACM0
habmin shows door sensor with green circle as node 2
configuration parameters for node are set as -
send sensory binary reports on open close events - on for close, off for open
send basic also similar
door status value always comes as closed , even when door is open
chris
(Chris Jackson)
October 11, 2015, 3:00pm
2
Can you provide a debug log showing the problem - ie data being received from the device when the door is open and closed.
I would also remove the refresh_interval
as it won’t do anything useful and could cause problems.
parag
(parag)
October 11, 2015, 3:06pm
3
log.pdf (393.2 KB)
Thanks Cris, Kindly find log attached
chris
(Chris Jackson)
October 11, 2015, 3:09pm
4
Can you post the log as a text file please - I can’t easily process it as a PDF…
I do note a lot of duplicate messages in your log - are you running on an RPi? You might be suffering from the RPi problem
parag
(parag)
October 11, 2015, 3:14pm
5
Sorry Chris
I can’t upload text file as the website does not allow it.
I am using ubuntu trusty on 32 bit machine
chris
(Chris Jackson)
October 11, 2015, 3:16pm
6
Can you attach it somewhere and post the link then? I really can’t work with a PDF as I have tools to read the log - it doesn’t work with PDF.
parag
(parag)
October 11, 2015, 3:18pm
7
can I email you the file, if you pls share email address
Regards
Parag
chris
(Chris Jackson)
October 11, 2015, 3:19pm
8
yes - it’s chris -at- cd-jackson.com
chris
(Chris Jackson)
October 11, 2015, 3:27pm
9
Got it… The duplication I saw isn’t duplication - it’s just you’re restarting the server a few times…
I really need a debug log to really see what’s happening - take a look in the wiki about how to change this (ie the zwave wiki page).
There are a lot of errors in this log though so you might like to try and resolve some of the exceptions such as address in use
parag
(parag)
October 11, 2015, 4:43pm
10
Chris,
I do not get Z WAVE logs, my logback.xml is as follows. I have enabled debug log. I am sending log file by email
best regards
Parag
<appender name="STDOUT" class="ch.qos.logback.core.ConsoleAppender">
<encoder>
<pattern>%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5level] [%-30.30logger{36}] - %msg%n</pattern>
</encoder>
</appender>
<appender name="FILE" class="ch.qos.logback.core.rolling.RollingFileAppender">
<file>${openhab.logdir:-logs}/openhab.log</file>
<rollingPolicy class="ch.qos.logback.core.rolling.TimeBasedRollingPolicy">
<!-- weekly rollover and archiving -->
<fileNamePattern>${openhab.logdir:-logs}/openhab-%d{yyyy-ww}.log.zip</fileNamePattern>
<!-- maximum number of archive files to keep -->
<maxHistory>30</maxHistory>
</rollingPolicy>
<encoder>
</encoder>
</appender>
<appender name="EVENTFILE" class="ch.qos.logback.core.rolling.RollingFileAppender">
<file>${openhab.logdir:-logs}/events.log</file>
<fileNamePattern>${openhab.logdir:-logs}/events-%d{yyyy-ww}.log.zip</fileNamePattern>
</rollingPolicy>
<encoder>
<pattern>%d{yyyy-MM-dd HH:mm:ss} - %msg%n</pattern>
</encoder>
</appender>
<logger name="runtime.busevents" level="INFO" additivity="false">
<appender-ref ref="EVENTFILE" />
<appender-ref ref="STDOUT" />
</logger>
<logger name="org.openhab" level="DEBUG"/>
<!-- this class gives an irrelevant warning at startup -->
<logger name="org.atmosphere.cpr.AtmosphereFramework" level="ERROR" />
<!-- temporary workaround for https://github.com/openhab/jmdns/issues/12 -->
<logger name="javax.jmdns" level="OFF"/>
<!-- temporary workaround for https://bugs.eclipse.org/bugs/show_bug.cgi?id=402750 -->
<logger name="OSGi" level="OFF" />
<!-- temporary workaround to circumvent error messages with any obvious effect -->
<logger name="org.atmosphere.cpr.AtmosphereFramework" level="OFF" />
<logger name="org.atmosphere.cpr.DefaultAnnotationProcessor" level="OFF" />
<root level="WARN">
<appender-ref ref="FILE" />
</root>
logs/zwave.log
logs/zwave-%d{yyyy-ww}.log.zip
30
%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5level] [%-30.30logger{36}:%-4line]- %msg%n
chris
(Chris Jackson)
October 11, 2015, 4:51pm
12
Unfortunately the log you sent has no zwave data in it… Somehow this needs to get resolved - I would have thought updating the logback files (both debug and normal) with the data in the wiki should work?
I note though that the events log does have both open and closed entries though so I guess the state is updating at least occasionally?
2015-10-10 11:06:31 - Door_Motion state updated to OPEN
2015-10-10 11:23:17 - Door_Motion state updated to CLOSED
parag
(parag)
October 11, 2015, 4:56pm
13
Chris,
if i have configuration parameter -
send sensory binary reports on open close events - on for open, off for close
I get state as OPEN
AND WHEN
I get state as CLOSED
I changed the option , hence the event log shows both states but closing/opening of door does not trigger any chnage in state
chris
(Chris Jackson)
October 11, 2015, 5:00pm
14
Is this configuration change a device parameter (I assume so from your message, but just checking).
So is your problem simply that the device doesn’t send an update when it changes? If so, have you checked that the association is set correctly?
parag
(parag)
October 11, 2015, 5:03pm
15
yes it is device parameter.
since i have only two nodes - controller and door sensor, i assumed i would not need association setting.
Please guide , is it required
chris
(Chris Jackson)
October 11, 2015, 5:04pm
16
parag:
is it required
Absolutely - associations are the mechanism zwave uses to notify the controller of changes. It doesn’t matter if you have 1, or 100 devices, if there is no association, then you won’t get updates.
parag
(parag)
October 11, 2015, 5:08pm
17
Thanks a lot Chris
it works now. state is updated now
chris
(Chris Jackson)
October 11, 2015, 5:09pm
18
Great - glad it’s working
parag
(parag)
October 11, 2015, 5:17pm
19
Chris You are very helpful . can’t thank you enough
Regards
Parag
