openhabian snapshot
I’m opening this new thread since the other thread I started also had questions about the UV levels. This one is specific to the paperui and the binary and motion channel of the MS6
I just set up an Aeotec MS6. Mostly it is working.
Though I never see motion or binary change in the paperui, they show in the log and work with rules.
And I get reports of temperature, luminance, humidity, and battery to display in paperui.
The items for the binary and motion are as follows:
Switch ms6_binary "MS6 Switch [%s]" {channel="zwave:device:16500637f6a:node17:sensor_binary"}
Switch ms6_motion "MS6 Motion [%s]" {channel="zwave:device:16500637f6a:node17:alarm_motion"}
In the log there is a ~0.5 second delay between the change of the binary to on and the change of the motion channel.
I guess I don’t fully understand what the MS6 is doing.
Are the “binary” and “motion” channels changing based on the PIR?
I note, habmin, that the binary channel shows triggered or untriggered. And, the motion shows alarm or ok.
But the following rule prints on or off for both:
rule "M6 Motion"
Item ms6_binary changed
logInfo("M6 Motion", "binary state: " + ms6_binary.state)
logInfo("M6 Motion", "motion state: " + ms6_motion.state)
But, I’d really like to know if it should change in paperui and if so, what have I got wrong…
