Hi all,
I just got 3 new Aeotech multisensor 6, model no ZW100-C. I able to setup the device with Z-Stick Gen 5 Z-Wave. Then I choose Binary Sensor & Alarm from Things section. I moved to Control section inside paper UI but it seems no alarm or motion is detected by openhab2. Please help me to figure it out where I am doing wrong?When I shake the sensor it seems openhab2 identify alarm inside log. Log is below for reference
2016-08-17 23:39:20.001 [INFO ] [smarthome.event.ItemStateEvent:43 ] - Wifi_Level updated to 0
2016-08-17 23:39:20.002 [INFO ] [s.event.ItemStateChangedEvent :43 ] - Wifi_Level changed from 2 to 0
2016-08-17 23:39:23.036 [DEBUG] [rialHandler$ZWaveReceiveThread:244 ] - Receive Message = 01 10 00 04 00 08 0A 71 05 00 00 00 FF 07 03 00 00 66
2016-08-17 23:39:23.036 [INFO ] [smarthome.event.ItemStateEvent:43 ] - zwave_serial_zstick_d4681df1_serial_sof updated to 263
2016-08-17 23:39:23.036 [DEBUG] [b.z.i.protocol.ZWaveController:1284 ] - Receive queue TAKE: Length=0
2016-08-17 23:39:23.036 [DEBUG] [o.b.z.i.protocol.SerialMessage:255 ] - Assembled message buffer = 01 10 00 04 00 08 0A 71 05 00 00 00 FF 07 03 00 00 66
2016-08-17 23:39:23.036 [INFO ] [s.event.ItemStateChangedEvent :43 ] - zwave_serial_zstick_d4681df1_serial_sof changed from 262 to 263
2016-08-17 23:39:23.036 [DEBUG] [b.z.i.protocol.ZWaveController:1285 ] - Process Message = 01 10 00 04 00 08 0A 71 05 00 00 00 FF 07 03 00 00 66
2016-08-17 23:39:23.036 [DEBUG] [b.z.i.protocol.ZWaveController:203 ] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 08 0A 71 05 00 00 00 FF 07 03 00 00
2016-08-17 23:39:23.036 [DEBUG] [ApplicationCommandMessageClass:42 ] - NODE 8: Application Command Request (ALIVE:GET_CONFIGURATION)
2016-08-17 23:39:23.036 [DEBUG] [ApplicationCommandMessageClass:152 ] - NODE 8: Incoming command class ALARM
2016-08-17 23:39:23.037 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:99 ] - NODE 8: Received Alarm Request V3
2016-08-17 23:39:23.037 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:103 ] - NODE 8: Process Alarm Report, V3, length 13
2016-08-17 23:39:23.037 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:125 ] - NODE 8: Alarm report - 7 = 0, sensor=0, event=3, status=255
2016-08-17 23:39:23.037 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:145 ] - NODE 8: Alarm Type = Burglar (7)
2016-08-17 23:39:23.038 [DEBUG] [b.z.i.protocol.ZWaveController:538 ] - Notifying event listeners: ZWaveAlarmValueEvent
2016-08-17 23:39:23.038 [DEBUG] [.b.z.handler.ZWaveThingHandler:896 ] - NODE 8: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2016-08-17 23:39:23.038 [DEBUG] [.b.z.handler.ZWaveThingHandler:905 ] - NODE 8: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2016-08-17 23:39:23.038 [DEBUG] [.b.z.handler.ZWaveThingHandler:1066 ] - NODE 8: Updating channel state zwave:device:d4681df1:node8:alarm_general to OFF [OnOffType]
2016-08-17 23:39:23.038 [DEBUG] [ApplicationCommandMessageClass:126 ] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
2016-08-17 23:39:23.038 [INFO ] [smarthome.event.ItemStateEvent:43 ] - zwave_device_d4681df1_node8_alarm_general updated to OFF
