I’ve migrated to Openhab ZWave controller and trying to figure out how to config this bulb to my liking. Spent almost a week reading other threads but still confused.
Basically what I need is ability to switch between Cold White / Warm White and RGB mode, control brightness in all three modes and color in RGB mode. I have all 3 channels configured and controls in sitemap, it seems like they all somehow interconnected and changing one will change the other.
Temperature channel will never stay on, after a second it will jump back to 0.
Brightness channel is even more mysterious as it is alway jumping a little bit back when you turn it on and when you set it to 0 jumping to something like 9 or 10, bulb stays off however and log has this entry:
NODE 13: Received COMMAND_CLASS_SWITCH_MULTILEVEL V2 SWITCH_MULTILEVEL_REPORT
NODE 13: Switch Multi Level report, value = 9
NODE 13: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
NODE 13: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=9
NODE 13: Updating channel state zwave:device:controller:node13:switch_dimmer to 9 [PercentType]
NODE 13: Updating channel state zwave:device:controller:node13:color_color to 9 [PercentType]
If needed I can provide my items and debug logs however at the moment I’m more interested in some explanations of this behaviour and examples of setup.
Hope somebody can help, thanks!
