I’m successfully using an Aeotec Z-Stick gen5 with my rapsperry and everything works as expected.
Now I would like to turn off led notification while the stick is connected to the usb port, but from the habmin panel I cannot set any parameter.
The manual of the stick describe parameter 81 of the serial-api for disabling led notification, how can I set this parameter using openhab ? I can set parameter of my other z-wave devices from habmin but I cannot set any parameter of the z-stick controller.
Currently it’s not possible to set parameters within controllers. This was disabled in the past as sending these commands to older controllers (ie not Gen5) caused the controller to not respond which had a number of unwanted side effects.
I’d not noticed that it was possible to disable the LED. Please can you add an issue into the GitHub issue tracker and I’ll look at adding this (I’d also like to disable it on mine - it’s annoying! ).
Enable soft reset - definitely not as that causes problems with Gen5 sticks.
SUC might help if you have devices that are moving around - it probably doesn’t hurt to set it, but I suspect it won’t make much difference unless you have a network that’s ‘a bit special’.
