Yes, it’s a long post but i wanted to include all the debugging i did prior to asking for help
I just got started into home automation and have been struggling for weeks to get my z-stick online in openhab2. I won’t begin to tell you the different setups i’ve tried so here is what i’m using currently (below). Please help!!!
Setup:
- HP Proliant DL360 G6 rack server
- Server OS: VMware ESXi 6.0.0-Update2
- SYBA 2 port USB 3.0 PCI-E card (I found the Proliant OOTB USB does not support 3.0…)
- Aeotec z-stick gen5 (plugged into the PCI-E card)
- VM OS: Ubuntu 17.04-server-amd64
- Software: openHABian latest stable release (installed 9/23)
* Used the openHABian Oracle Java option
* Java version “1.8.0_144”
* Java™ SE Runtime Environment (build 1.8.0_144-b01)
* Java HotSpot™ 64-Bit Server VM (build 25.144-b01, mixed mode)
Problem:
No matter what I try the z-stick ‘thing’ will not show ‘online’. I’ve done tons of searching… here is all the information i’ve gathered to root cause the problem.
The USB 3.0 card is recognized by the server and i passed through to the VM
I verified the VM finds the USB card:
administrator@ubuntu:~$ lspci
03:00.0 USB controller: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller (rev 03) -
openhab user permissions:
administrator@ubuntu:~$ groups openhab
openhab : openhab tty dialout -
I see the serial port in /dev/
administrator@ubuntu:~$ ls -altr /dev/tty*
crw-rw---- 1 root dialout 4, 64 Sep 24 11:52 /dev/ttyS0 -
Binding and z-stick config in openhab
Z-Wave Binding Installed binding-zwave - 2.1.0 (Chris Jackson @chris)Z-Wave Serial Controller OFFLINE
zwave:serial_zstick:8f7c297dSerial Port config: /dev/ttyS0
Logs on startup
2017-09-24 11:51:01.802 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://10.0.0.94:8080
2017-09-24 11:51:01.802 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://10.0.0.94:8443
2017-09-24 11:51:02.104 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-09-24 11:51:02.133 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-09-24 11:51:02.215 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-09-24 11:51:02.331 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-09-24 11:51:03.302 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/ttyS0’
2017-09-24 11:51:03.304 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:8f7c297d’ changed from UNINITIALIZED to INITIALIZING
2017-09-24 11:51:03.308 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:8f7c297d’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2017-09-24 11:51:03.330 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2017-09-24 11:51:03.336 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2017-09-24 11:51:03.342 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2017-09-24 11:51:03.343 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false. -
I see home odd logs when running dmesg command but not able to determine if its a real problem or not.
administrator@ubuntu:~$ dmesg | grep -i tty
[ 0.000000] console [tty0] enabled
[ 2.094739] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 2.122365] 00:07: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[ 0.965815] pci 0000:03:00.0: System wakeup disabled by ACPI
[ 0.965964] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with ‘pcie_aspm=force’
[ 0.966195] pci 0000:00:15.0: PCI bridge to [bus 03]
[ 0.966323] pci 0000:00:15.0: bridge window [mem 0xfd500000-0xfd5fffff]
[ 0.966596] pci 0000:00:15.1: PCI bridge to [bus 04]
[ 0.966712] pci 0000:00:15.1: bridge window [io 0x7000-0x7fff]
[ 0.966728] pci 0000:00:15.1: bridge window [mem 0xfd100000-0xfd1fffff]
[ 0.966770] pci 0000:00:15.1: bridge window [mem 0xeb800000-0xeb8fffff 64bit pref]
[ 0.967011] pci 0000:00:15.2: PCI bridge to [bus 05]
[ 0.967127] pci 0000:00:15.2: bridge window [io 0xb000-0xbfff]
[ 0.967142] pci 0000:00:15.2: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.967172] pci 0000:00:15.2: bridge window [mem 0xeb400000-0xeb4fffff 64bit pref]
[ 0.967420] pci 0000:00:15.3: PCI bridge to [bus 06]
[ 0.967550] pci 0000:00:15.3: bridge window [mem 0xfc900000-0xfc9fffff]
[ 0.967579] pci 0000:00:15.3: bridge window [mem 0xeb000000-0xeb0fffff 64bit pref]
[ 0.967823] pci 0000:00:15.4: PCI bridge to [bus 07]
[ 0.967952] pci 0000:00:15.4: bridge window [mem 0xfc500000-0xfc5fffff]
[ 0.967982] pci 0000:00:15.4: bridge window [mem 0xeac00000-0xeacfffff 64bit pref]
[ 0.968224] pci 0000:00:15.5: PCI bridge to [bus 08]
[ 0.968353] pci 0000:00:15.5: bridge window [mem 0xfc100000-0xfc1fffff]
[ 0.968383] pci 0000:00:15.5: bridge window [mem 0xea800000-0xea8fffff 64bit pref]
[ 0.968626] pci 0000:00:15.6: PCI bridge to [bus 09]
[ 0.968756] pci 0000:00:15.6: bridge window [mem 0xfbd00000-0xfbdfffff]
[ 0.968785] pci 0000:00:15.6: bridge window [mem 0xea400000-0xea4fffff 64bit pref]
[ 0.969028] pci 0000:00:15.7: PCI bridge to [bus 0a]
[ 0.969202] pci 0000:00:15.7: bridge window [mem 0xfb900000-0xfb9fffff]
[ 0.969232] pci 0000:00:15.7: bridge window [mem 0xea000000-0xea0fffff 64bit pref]
[ 0.969531] pci 0000:0b:00.0: [15ad:07b0] type 00 class 0x020000
[ 0.971114] pci 0000:0b:00.0: reg 0x10: [mem 0xfd4fc000-0xfd4fcfff]
[ 1.005998] pci 0000:0b:00.0: reg 0x14: [mem 0xfd4fd000-0xfd4fdfff]
[ 1.007555] pci 0000:0b:00.0: reg 0x18: [mem 0xfd4fe000-0xfd4fffff]
[ 1.009093] pci 0000:0b:00.0: reg 0x1c: [io 0x4000-0x400f]
[ 1.013752] pci 0000:0b:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 1.014084] pci 0000:0b:00.0: supports D1 D2
[ 1.014086] pci 0000:0b:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.014227] pci 0000:0b:00.0: System wakeup disabled by ACPI
[ 1.014375] pci 0000:0b:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with ‘pcie_aspm=force’
administrator@ubuntu:~$ dmesg | grep -i ASPM
[ 0.718673] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
