We need to determine if this is a UI or binding issue I suspect UI and am not sure how to best approach this.
In order to further narrow down the problem, here is some more logging, on step 2 (= enter -5 and press “Save”).
Note however that for the “CONFIGURATION_REPORT” the Value=256
might be misleading; at 16:06:54.771
the value is -1279
according to the log output at 16:06:54.781
-1279
corresponds to "FB01"
which eqals to -5
(high byte = Temperature Calibration Offset) and 1 (low byte = Temperature Calibration Unit). I.e. the value was correctly set in the device.
Well, seems the "FB"
is interpreted as 251
instead of -5
. But the update of the displayed value is only done lateron in Step 3 (when -5 becomes 251).
Does this provide enough inside for problem resolution?
Here is the log output:
2021-01-04 16:03:28.475 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Configuration update set config_201_2_0000FF00 to -5 (BigDecimal)
2021-01-04 16:03:28.476 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Set sub-parameter 201 from -5 / 0000FF00
2021-01-04 16:03:28.477 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Parameter 201 set value FFFFFFFB mask 0000FF00
2021-01-04 16:03:28.478 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 63: Creating new message for application command CONFIGURATIONCMD_GET
2021-01-04 16:03:28.479 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: SECURITY not supported
2021-01-04 16:03:28.480 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-01-04 16:03:28.481 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Bump transaction 1196 priority from Config to Immediate
2021-01-04 16:03:28.482 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Adding to device queue
2021-01-04 16:03:28.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Added 1196 to queue - size 3
2021-01-04 16:03:28.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-01-04 16:06:53.275 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 3F 02 84 07 4D
2021-01-04 16:06:53.276 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=63, callback=0, payload=00 3F 02 84 07
2021-01-04 16:06:53.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=63, callback=0, payload=00 3F 02 84 07
2021-01-04 16:06:53.278 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-01-04 16:06:53.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Application Command Request (ALIVE:DONE)
2021-01-04 16:06:53.279 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: resetResendCount initComplete=true isDead=false
2021-01-04 16:06:53.280 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: Is awake with 1 messages in the queue
2021-01-04 16:06:53.280 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: Start sleep timer at 1000ms
2021-01-04 16:06:53.281 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2021-01-04 16:06:53.287 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 63: Node Status event - Node is AWAKE
2021-01-04 16:06:53.287 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Commands processed 1.
2021-01-04 16:06:53.288 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@10d28da.
2021-01-04 16:06:53.289 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-01-04 16:06:53.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-01-04 16:06:53.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:53.292 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-01-04 16:06:53.293 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 3F 03 70 05 C9 25 8D CE
2021-01-04 16:06:53.294 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 63: Sending REQUEST Message = 01 0A 00 13 3F 03 70 05 C9 25 8D CE
2021-01-04 16:06:53.295 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-01-04 16:06:53.295 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 1196: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 141
2021-01-04 16:06:53.297 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-01-04 16:06:53.298 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-01-04 16:06:53.299 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-01-04 16:06:53.299 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1196: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 141
2021-01-04 16:06:53.300 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-01-04 16:06:53.301 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:53.301 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:53.303 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-01-04 16:06:53.304 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:53.305 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:53.306 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1196: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 141
2021-01-04 16:06:53.307 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-01-04 16:06:53.307 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1196: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 141
2021-01-04 16:06:53.308 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:53.309 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 63: sentData successfully placed on stack.
2021-01-04 16:06:53.310 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1196: Advanced to WAIT_REQUEST
2021-01-04 16:06:53.311 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: TID 1196: Transaction not completed
2021-01-04 16:06:53.311 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:53.312 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:53.702 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 8D 00 00 28 4E
2021-01-04 16:06:53.703 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=141, payload=8D 00 00 28
2021-01-04 16:06:53.704 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=141, payload=8D 00 00 28
2021-01-04 16:06:53.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1196: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 141
2021-01-04 16:06:53.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-01-04 16:06:53.706 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1196: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 141
2021-01-04 16:06:53.707 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 1196: (Callback 141)
2021-01-04 16:06:53.708 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-01-04 16:06:53.709 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 1196: callback 141
2021-01-04 16:06:53.709 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=141, payload=8D 00 00 28
2021-01-04 16:06:53.710 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 63: SendData Request. CallBack ID = 141, Status = Transmission complete and ACK received(0)
2021-01-04 16:06:53.711 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: resetResendCount initComplete=true isDead=false
2021-01-04 16:06:53.712 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1196: Advanced to WAIT_DATA
2021-01-04 16:06:53.713 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: TID 1196: Transaction not completed
2021-01-04 16:06:53.713 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:53.714 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:53.782 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: WakeupTimerTask 1 Messages waiting, state DONE
2021-01-04 16:06:53.861 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 3F 06 70 06 C9 02 00 01 72
2021-01-04 16:06:53.862 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=63, callback=0, payload=00 3F 06 70 06 C9 02 00 01
2021-01-04 16:06:53.869 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=63, callback=0, payload=00 3F 06 70 06 C9 02 00 01
2021-01-04 16:06:53.869 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-01-04 16:06:53.870 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Application Command Request (ALIVE:DONE)
2021-01-04 16:06:53.870 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: resetResendCount initComplete=true isDead=false
2021-01-04 16:06:53.871 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: Incoming command class COMMAND_CLASS_CONFIGURATION, endpoint 0
2021-01-04 16:06:53.872 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: SECURITY not supported
2021-01-04 16:06:53.873 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 63: Received COMMAND_CLASS_CONFIGURATION V1 CONFIGURATIONCMD_REPORT
2021-01-04 16:06:53.873 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 63: Node configuration report, parameter = 201, value = 1, size = 2
2021-01-04 16:06:53.875 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
2021-01-04 16:06:53.877 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CONFIGURATION, value=org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@14d72e6
2021-01-04 16:06:53.877 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Update CONFIGURATION 201/2 to 1
2021-01-04 16:06:53.878 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Updating sub-parameter 201 to 64257
2021-01-04 16:06:53.879 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Setting parameter 201 to 64257
2021-01-04 16:06:53.879 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 63: Creating new message for application command CONFIGURATION_SET
2021-01-04 16:06:53.880 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: SECURITY not supported
2021-01-04 16:06:53.881 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-01-04 16:06:53.882 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Bump transaction 1198 priority from Config to Immediate
2021-01-04 16:06:53.883 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Adding to device queue
2021-01-04 16:06:53.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Added 1198 to queue - size 3
2021-01-04 16:06:53.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:53.885 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 63: Creating new message for application command CONFIGURATIONCMD_GET
2021-01-04 16:06:53.886 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: SECURITY not supported
2021-01-04 16:06:53.886 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-01-04 16:06:53.887 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Bump transaction 1199 priority from Config to Immediate
2021-01-04 16:06:53.888 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Adding to device queue
2021-01-04 16:06:53.888 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Added 1199 to queue - size 4
2021-01-04 16:06:53.889 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:53.890 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Commands processed 1.
2021-01-04 16:06:53.890 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f8ed3c.
2021-01-04 16:06:53.891 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f8ed3c.
2021-01-04 16:06:53.891 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: notifyTransactionResponse TID:1196 DONE
2021-01-04 16:06:53.892 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-01-04 16:06:53.893 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2021-01-04 16:06:53.894 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-01-04 16:06:53.894 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:53.894 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-01-04 16:06:53.895 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 3F 06 70 04 C9 02 FB 01 25 8E 36
2021-01-04 16:06:53.896 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 63: Sending REQUEST Message = 01 0D 00 13 3F 06 70 04 C9 02 FB 01 25 8E 36
2021-01-04 16:06:53.896 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-01-04 16:06:53.897 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 1198: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 142
2021-01-04 16:06:53.898 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-01-04 16:06:53.899 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-01-04 16:06:53.900 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-01-04 16:06:53.901 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1198: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 142
2021-01-04 16:06:53.901 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-01-04 16:06:53.902 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:53.902 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:53.905 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-01-04 16:06:53.906 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:53.907 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:53.907 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1198: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 142
2021-01-04 16:06:53.908 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-01-04 16:06:53.908 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1198: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 142
2021-01-04 16:06:53.909 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:53.909 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 63: sentData successfully placed on stack.
2021-01-04 16:06:53.910 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1198: Advanced to WAIT_REQUEST
2021-01-04 16:06:53.911 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: TID 1198: Transaction not completed
2021-01-04 16:06:53.911 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:53.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:54.282 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: WakeupTimerTask 2 Messages waiting, state DONE
2021-01-04 16:06:54.282 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: No more messages, go back to sleep
2021-01-04 16:06:54.283 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 63: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2021-01-04 16:06:54.284 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: SECURITY not supported
2021-01-04 16:06:54.284 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-01-04 16:06:54.285 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@2587ee
2021-01-04 16:06:54.286 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Bump transaction 1200 priority from Immediate to Immediate
2021-01-04 16:06:54.287 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Adding to device queue
2021-01-04 16:06:54.288 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Added 1200 to queue - size 4
2021-01-04 16:06:54.288 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:54.297 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 8E 00 00 28 4D
2021-01-04 16:06:54.299 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=142, payload=8E 00 00 28
2021-01-04 16:06:54.300 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=142, payload=8E 00 00 28
2021-01-04 16:06:54.300 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1198: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 142
2021-01-04 16:06:54.301 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-01-04 16:06:54.301 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1198: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 142
2021-01-04 16:06:54.302 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 1198: (Callback 142)
2021-01-04 16:06:54.302 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-01-04 16:06:54.303 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 1198: callback 142
2021-01-04 16:06:54.304 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=142, payload=8E 00 00 28
2021-01-04 16:06:54.304 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 63: SendData Request. CallBack ID = 142, Status = Transmission complete and ACK received(0)
2021-01-04 16:06:54.305 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: resetResendCount initComplete=true isDead=false
2021-01-04 16:06:54.305 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1198: Transaction COMPLETED
2021-01-04 16:06:54.306 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Response processed after 409ms
2021-01-04 16:06:54.306 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: TID 1198: Transaction completed
2021-01-04 16:06:54.307 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: notifyTransactionResponse TID:1198 DONE
2021-01-04 16:06:54.308 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-01-04 16:06:54.308 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:54.309 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-01-04 16:06:54.309 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 3F 03 70 05 C9 25 8F CC
2021-01-04 16:06:54.310 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 63: Sending REQUEST Message = 01 0A 00 13 3F 03 70 05 C9 25 8F CC
2021-01-04 16:06:54.311 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-01-04 16:06:54.311 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 1199: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 143
2021-01-04 16:06:54.312 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-01-04 16:06:54.313 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-01-04 16:06:54.314 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-01-04 16:06:54.315 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1199: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 143
2021-01-04 16:06:54.316 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-01-04 16:06:54.316 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:54.317 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:54.318 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-01-04 16:06:54.320 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:54.321 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:54.321 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1199: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 143
2021-01-04 16:06:54.322 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-01-04 16:06:54.322 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1199: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 143
2021-01-04 16:06:54.323 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:54.323 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 63: sentData successfully placed on stack.
2021-01-04 16:06:54.324 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1199: Advanced to WAIT_REQUEST
2021-01-04 16:06:54.325 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: TID 1199: Transaction not completed
2021-01-04 16:06:54.325 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:54.326 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:54.613 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 8F 00 00 1E 7A
2021-01-04 16:06:54.615 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=143, payload=8F 00 00 1E
2021-01-04 16:06:54.617 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=143, payload=8F 00 00 1E
2021-01-04 16:06:54.618 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1199: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 143
2021-01-04 16:06:54.619 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-01-04 16:06:54.620 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1199: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 143
2021-01-04 16:06:54.621 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 1199: (Callback 143)
2021-01-04 16:06:54.622 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-01-04 16:06:54.623 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 1199: callback 143
2021-01-04 16:06:54.624 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=143, payload=8F 00 00 1E
2021-01-04 16:06:54.625 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 63: SendData Request. CallBack ID = 143, Status = Transmission complete and ACK received(0)
2021-01-04 16:06:54.627 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: resetResendCount initComplete=true isDead=false
2021-01-04 16:06:54.628 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1199: Advanced to WAIT_DATA
2021-01-04 16:06:54.629 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: TID 1199: Transaction not completed
2021-01-04 16:06:54.630 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:54.631 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-01-04 16:06:54.771 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 3F 06 70 06 C9 02 FB 01 89
2021-01-04 16:06:54.773 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=63, callback=0, payload=00 3F 06 70 06 C9 02 FB 01
2021-01-04 16:06:54.775 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=63, callback=0, payload=00 3F 06 70 06 C9 02 FB 01
2021-01-04 16:06:54.776 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-01-04 16:06:54.777 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Application Command Request (ALIVE:DONE)
2021-01-04 16:06:54.778 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: resetResendCount initComplete=true isDead=false
2021-01-04 16:06:54.779 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: Incoming command class COMMAND_CLASS_CONFIGURATION, endpoint 0
2021-01-04 16:06:54.780 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 63: SECURITY not supported
2021-01-04 16:06:54.781 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 63: Received COMMAND_CLASS_CONFIGURATION V1 CONFIGURATIONCMD_REPORT
2021-01-04 16:06:54.781 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 63: Node configuration report, parameter = 201, value = -1279, size = 2
2021-01-04 16:06:54.782 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
2021-01-04 16:06:54.783 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CONFIGURATION, value=org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@14d72e6
2021-01-04 16:06:54.784 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Update CONFIGURATION 201/2 to -1279
2021-01-04 16:06:54.785 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Commands processed 1.
2021-01-04 16:06:54.786 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1b41724.
2021-01-04 16:06:54.787 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1b41724.
2021-01-04 16:06:54.788 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: notifyTransactionResponse TID:1199 DONE
2021-01-04 16:06:54.789 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-01-04 16:06:54.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2021-01-04 16:06:54.791 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-01-04 16:06:54.792 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-01-04 16:06:54.793 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-01-04 16:06:54.794 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 3F 02 84 08 25 90 E1
2021-01-04 16:06:54.795 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 63: Sending REQUEST Message = 01 09 00 13 3F 02 84 08 25 90 E1
2021-01-04 16:06:54.796 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-01-04 16:06:54.797 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-01-04 16:06:54.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-01-04 16:06:54.800 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 1200: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 144
2021-01-04 16:06:54.801 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-01-04 16:06:54.802 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1200: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 144
2021-01-04 16:06:54.803 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-01-04 16:06:54.804 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-01-04 16:06:54.806 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:54.807 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:54.808 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1200: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 144
2021-01-04 16:06:54.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-01-04 16:06:54.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1200: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 144
2021-01-04 16:06:54.811 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-01-04 16:06:54.812 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 63: sentData successfully placed on stack.
2021-01-04 16:06:54.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1200: Advanced to WAIT_REQUEST
2021-01-04 16:06:54.814 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 63: TID 1200: Transaction not completed
2021-01-04 16:06:54.815 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
Filtered logs are useless for troubleshooting. we need to add that to the documentation.
And I just got the following output from the REST API (extracts):
"config_201_2_000000FF": 1,
"config_201_2": -1279,
"config_201_2_0000FF00": 251,
So … any knowledgeable person who understands in which part of openHAB the bug is?
With best regards,
Gert
So much has changed in the core, who knows??
I was looking for a similar setup with another device whe I could try to reprocuce the error. Could not do this the last time due to time restrictions.
I found a Fibaro flood sensor in my device selection that allows for a temperature offset as well. It is a two byte value, but not a split one as with the ZW100. Testing was a bit time consuming as it is a battery driven device, but I can tell that negative values for the offset did work.
When chanhing the configuration parameter I got a message
2021-01-04 17:57:16.666 [INFO ] [openhab.event.ConfigStatusInfoEvent ] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_73_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_3, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
in events.log, similar to the change of the configuration on the ZW100. Don’t think that matters.
As it worked ok for the flood sensor, that may indicate an issue with the combined value and the masking of the two parameter parts in one two-byte field. Just a suspicion…
I’ll try to look for another device that may have a similar setup as the ZW100. Will keep you posted…
two byte values can sometimes be split in the database to make it easier to enter changes.
Found only one more device with a similar config parameter: the Spirit Z-Wave Plus allows for a temperature offset as well. Situation is not identical to the ZW100, though. It is a one byte value in this case.
Maybe worth to mention: the documentation clearly outlines that negative values are indicated with the highest bit set to “1”:
0xCE-0x32 Offsets the measured temperature by -5,0°C – (+)5,0°C
Neither the documentation of the Fibaro flood sensor nor the docs for the ZW100 tell us anything about how negative values need to be coded.
From my p.o.v. the DEBUG logs from the ZW100 would help to see how the values are reported from the device itself and then we might conclude from that what needs to be checked or done?
My interpretation:
config_201_2_000000FF is the lowest byte of the two-byte value, the “000000FF” is similar to a netmask in network configuration, it filters out everything beyond the low byte. It leaves a “1” so you have configured for degrees Celsius.
config_201_2_0000FF00 is the high byte, similarly filtered off are the low byte and (does not really matter as we only have two bytes anyway) everything above byte 2. It leaves a “251” in decimal which indicates that negative values are represented with the highest bit set to “1”. That fits the description in the device documentation as without the highest bit in a byte the range is only plus/minus 128.
config_201_2 is the whole two-byte value:
value high byte * 256 plus value low byte
-5 * 256 + 1 = -1279
My conclusion: negative values are to be coded wit the highest bit set to 1. But I cannot tell where in the chain of data transmissions and conversions the bug may be.
@stefan.oh: thank you very much for taking the time to further investigate, also on other devices!
@chris: could you help there? Is this a problem with the zwave binding for negative values of parameters such as config_201_2_0000FF00
? I.e. should config_201_2_0000FF00
be reported by the binding to be -5 instead of 251?
Thank you a lot!
Gert
I am not sure how to continue on this issue.
Hmmm, unless someone tells me to do otherwise, I will submit a bug report against the zwave binding. Is this ok @chris ?
Best regards,
Gert
I opened an issue, here: No negative values for config_201_2_0000FF00 Aeotec ZW100 · Issue #1503 · openhab/org.openhab.binding.zwave · GitHub
Let’s see what happens.
Again, thank you very much to all
Gert
This may be unrelated, but I receive the exact same error message with a “XL624 Touchscreen Comfort Control Thermostat” (Trane) when changing parameters.
The UI can contain values, loaded from the thermostat, which are out of range according to the model. In my case, the “10: Minimum Off Time” was set to 4 minutes when the minimum is 5 minutes in the model. It was set this way through the thermostat by the installer.
That’s exactly the same situation that I have for the Aeotec ZW100 Temperature Calibration Value! And finally the error message occurs.
Gert
Gert,
If you click on “Show Advanced” and then save, it might show you the error. That’s how I found it.
-M
I am now with 3.1.0:
- by now, I cant change any value for either of my two ZW100 sensors
- I do not see any red values even with “Show Advanced” checkbox activated
- So no chance for me to change values for my ZW100 sensors
- actually, I already had this problem with 3.0.2; I just wanted to wait for 3.1.0., but the problem is still there
My log only contains:
2021-06-28 17:26:38.790 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 63: Configuration update received
2021-06-28 17:26:38.801 [ERROR] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - No message body writer has been found for class java.util.Collections$UnmodifiableMap, ContentType: */*
Is there a log that I could provide with different log settings? Someone willing to look at that?
Otherwise, what other solution could I use? Maybe Domoticz would be helpful?
Thanks,
Gert
New information: when I set DEBUG for the whole org.openhab, then the log is (here for node 28)
2021-06-28 19:00:34.123 [DEBUG] [onfig.core.ConfigDescriptionRegistry] - No config description found for 'thing:zwave:device:5d681cf1:node28', using alias 'thing-type:zwave:aeon_zw100_01_008' instead
2021-06-28 19:00:34.140 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Configuration update received
2021-06-28 19:00:34.158 [DEBUG] [st.core.internal.thing.ThingResource] - Config description validation exception occurred for thingUID zwave:device:5d681cf1:node28 - Messages: {config_9_2=The value must not be greater than 1.}
2021-06-28 19:00:34.190 [ERROR] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - No message body writer has been found for class java.util.Collections$UnmodifiableMap, ContentType: */*
From the “Code” tab:
config_9_2: 256
Edit:
So my conclusion is that an error was introduced in the device database for ZW100, firmware 1.8 (my node 28 is firmare 1.8). The entry in the device database for 1.13 seems to be correct (my node 63 is firmware 1.13).
From “Code” tab of the 1.13 device:
config_9_2_00000100: 1
How can that entry in the device database for ZW100, firmware 1.8, get corrected?
Thanks,
Gert
Try deleting the Think from OH (NOT exclude) and adding it back to get the latest binding database settings.
Failing that perhaps the log viewer can help Be sure to use unfiltered DEBUG logs.
Thank you for your advice. Here are the few things that I tried:
Deleting & Adding
@Bruce_Osborne as you suggested, I deleted the thing and added it back; however there was no change.
I guess the database configuration is buggy for firmware 1.8 regarding parameter 9. -
Firmware Upgrade
To evade the problem I upgraded the firmware to the current version (which is 1.14) because I know that the bug with parameter 9 does not exist there.
However, when I tried to save settings, again it did not work. Setting DEBUG for org.openhab revealed that problem with parameter 81. This was not red in the UI, but visible in the debug log. Setting Parameter 81 to “Enable LED blinking” solved that problem and finally I am able to configure the device
To summarize from my viewpoint:
- setting values for firmware 1.8 did work with older openHAB versions (I believe <= 3.0.0), but does not work with the current version of openHAB due to what I guess is an error in the configuration for parameter 9.
- the problem for firmware 1.14, parameter 81, I did not further investigate in detail there.
- Gladly, now I can configure my devices again thanks to setting DEBUG for the whole org.openhab.
With best greetings,
Gert
