Build 931
Windows 8.1
HABmin -> Configuration -> Things -> ZW111 node -> Channels -> Brightness
Linked a dimmer Item. Then attempted to set “Restore Last Value” to “Restore Full Brightness” in the Channel Configuration. On clicking Save, nothing is sent on the COM port to the zstick controller. The dimmer indeed restores to last setting rather than full brightness.
Am I doing something incorrect? Is this not yet supported? Or maybe the ZW111 does not actually support the setting?
Then it also does not appear to actually do anything either. That is, making this setting for the channel does not make the dimmer Item tell the ZW111 to turn on to full 99.
This may be because something else is broken: The channel setting does not stick, and always shows “Restore Last Value.”
Or it may be that Linked Items are a bit broken at least in the UI. For instance, after setting “Restore Last Value” in HABmin I went to Bindings then back to the ZW111 Thing and the channel binding had disappeared, though it is still on the Sitemap and still toggles the dimmer. So who knows where the setting is being stored. This is around the time that I have to delete everything in the DBs and start over.
btw: The Overview text for parameter 81 says Group 4 rather than Group 3.
No - it won’t do this. It should tell the device to turn on to the last value the device used. There is a specific value that is sent to tell the device to do this. Check the logs to see what it is actually sending.
Just to be clear: Are you stating that if I select “Restore Full Brightness” and hit Save, then the next time I turn on the light via an Item bound to that channel, openHAB should instead tell the channel to “Restore Last Value?” If so, then what is that channel configuration for? Should I be using some other type of Item to get the expected result?
I thought you were wanting to restore the last value, so in this case, it sends 255. If you want to switch to full brightness, then select that option and it will send 99.
I think that what you are saying is that this is happening ok?
Ah. No, my complaint is that it is definitely not happening. It always sends 255. Additionally, if I leave that setting in the HABmin UI and then return, my Saved change is no longer set. Might be related. That is, it might be saving the wrong value.
