If it is fully discoveres there should be an xml file in the zwave folder of userdata. That can be used, along with the manual, to add an entry to the community supported database.
Here is the database guide.
Uploaded xml files for the Aeotec ZWA011 and ZWA012. First is a Door/Window Sensor 7 and the other is the Pro version that adds tilt sensing and terminals to do a dry contact.
I added pictures and PDF manuals. Wasn’t sure what some of the information should be so I left it blank for now.
I’ve added parameters and associations according to the user manual. I’ve never done this before so I really don’t know if I’ve done it correctly or not. Did run into a few things that I couldn’t figure out.
parameter 8 - Group 2 on value
parameter 9 - Group 2 off value
- couldn't figure out how to define a range option of 0-99
parameter 10 - Group 2 On time delay
parameter 11 - Group 2 Off time delay
- couldn't figure out how to define a range option of 0-32400
Once this is done I will have a ZWA012 to add also that is based on the same sensor but adds a tilt sensor and dry contacts.
I tried to create a ticket on opensmarthouse.org, but I keep getting a 403 back
I just received some new Aeotec Limited ZWA011 Door/Window Sensor 7 (database id 1389), but they identify with another device type, than the one in the database (0002:000B instead of 0102:000B). It could be because mine are EU versions (ZWA011-C), but i’m not sure.
The database guide mentions uploading my xml to resolve multiple device-types, but I can’t find the function, and I am not sure how to do it the correct way, so please advise
Second, just to get it to work in my openHAB, I tried changing the type in my local build and got it included, but the sensors did not trip. By looking at the log I could see that the configured channels were wrong (different event-ID’s than expected), so by changing alarm_burgler to alarm_tamper and alarm_access to sensor_door, they now work.
I strongly doubt that this only applies for my sensors, but that it is wrong in the database. Have you been able to test it in openHAB @BiloxiGeek?
If I understand this discussion aright, the “Aeotec ZWA011” sensor has been added to the database.
But when I click on the “full list of supported things” in the documentation (Stable 3.3.0 / Zwave-Binding) I cannot find this product. The upgrade of the database has occurred in 2021. What is the reason that I cannot find it now in the database?
I picked this issue up from github, so the developer is aware. I think he is pretty busy with his regular job at the moment. Always check the actual DB if in doubt.
