Hello everyone,
Once in a while(so like once per 2-3 months) I got the problem that my Zwave usb stick goes offline. When I reboot the NAS server, everything is back to normal again. The only thing is, I want to solve this. Because when I’ll be expanding my home automation with security, I don’t want any errors that will cause my devices to be offline. Here is the log corresponding log file:
2020-11-16 00:00:02.749 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.zwave.handler.ZWaveThingHandler@2aee2a7a': Timer already cancelled.
java.lang.IllegalStateException: Timer already cancelled.
at java.util.Timer.sched(Timer.java:397) ~[?:1.8.0_212]
at java.util.Timer.schedule(Timer.java:208) ~[?:1.8.0_212]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.startTransactionTimer(ZWaveTransactionManager.java:1016) ~[?:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.addTransactionToQueue(ZWaveTransactionManager.java:388) ~[?:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.queueTransactionForSend(ZWaveTransactionManager.java:344) ~[?:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.enqueue(ZWaveController.java:505) ~[?:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.sendData(ZWaveController.java:889) ~[?:?]
at org.openhab.binding.zwave.handler.ZWaveControllerHandler.sendData(ZWaveControllerHandler.java:479) ~[?:?]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.handleCommand(ZWaveThingHandler.java:1191) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_212]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_212]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_212]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_212]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy1643.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_212]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_212]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_212]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212]
If anyone knows how to deal with this error, please let me know!!
Thanks in advance
