If I downgrade to 2.5.1-2 ( sudo apt-get install openhab2=2.5.1-2 ) , it works fine again.
Here’s the error:
2020-02-21 20:38:00.207 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Lock: Update lock states after alarm_raw event': cannot invoke method public abstract java.lang.String org.eclipse.smarthome.core.items.Item.getName() on null
I’m using a common config for Yale-type locks for mapping JSON data
rule "Lock: Update lock states after alarm_raw event"
Item Lock_SideGarage_Alarm_Raw changed
val actionItem = gLock.members.findFirst[ item | item.name.toString == triggeringItem.name.toString.replace("_Alarm_Raw","") ]
logInfo("Rules", "Lock: Alarm events: {}=[{}]",actionItem.name,triggeringItem.state.toString)
switch (transform("JSONPATH", "$.type", triggeringItem.state.toString)) {
case "0" : {
// do nothing
case "21" : {
actionItem.postUpdate(ON)
vGR_MA_Lock.postUpdate(ON)
logInfo("Rules", "Case 21 executed")
case "24" : {
logInfo("Rules", "Case 24 executed")
<snip>
I feel like the error is one of these three lines:
but I’m not sure what to do, since it works fine in 2.5.1-2 but only breaks when I upgrade to 2.5.2-1 and quite frankly I’m not sure how to debug that or where to even start.
Seems like quite a few people are using this rule, so I figured I would post this since others will likely run into the same issue.
Hope someone can provide some pointers!
