Hallo!
Recently, I updated the Homematic CCU2 to version 2.27.8. Since then in Openhab2 with Homematic binding 2.0.0 my things are all offline but not the CCU2. After deleting everything, I can just find the CCU2 but no things are found anymore.
The log tells “me”…
21:57:11.922 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'homematic:bridge:736db758' changed from INITIALIZING to ONLINE
And on every search for thing I can read …
21:58:29.229 [ERROR] [very.HomematicDeviceDiscoveryService] -
java.io.IOException
at org.openhab.binding.homematic.internal.communicator.CcuGateway.sendScript(CcuGateway.java:235)[186:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.sendScriptByName(CcuGateway.java:205)[186:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.sendScriptByName(CcuGateway.java:193)[186:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.loadDeviceNames(CcuGateway.java:125)[186:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.getDeviceDescriptions(AbstractHomematicGateway.java:421)[186:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.loadAllDeviceMetadata(AbstractHomematicGateway.java:358)[186:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.discovery.HomematicDeviceDiscoveryService$1.run(HomematicDeviceDiscoveryService.java:108)[186:org.openhab.binding.homematic:2.0.0]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Caused by: java.util.concurrent.TimeoutException
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:109)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:655)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.sendScript(CcuGateway.java:225)[186:org.openhab.binding.homematic:2.0.0]
... 13 more
Any suggestions what to do?
Thanks a lot …
