I run OpenHAB in docker on a raspberry pi and just noticed that the cards in Main UI sometimes don’t show the item state anymore.
This worked in OH 3.0, but there seems to be an issue in 3.1?
I have only the “HTTP binding” and the “Dresden Elektronik deCONZ Binding” installed, but problem exists for both bindings.
I can confirm this. There was once a change because of empty pages when switching to another tab immediately after loading. UnfortunateIy I can’t find the issue anymore. I’m quite sure it did start with this change.
We should create a new issue on Github…and it’s more related to openHAB 3.1 (and 3.2.0.M2)
I also notice this on Safari on iPhone, iPad and Macbook.
I did not notice it on Chromium on a Raspberry PI which is continuously showing the main UI. I suspect it is related to a browser tab which is not continuously shown.
I am on openhab 3.1.0 on a raspberry pi v4 and this is always happening in one windows 10 (professional) PC that I do not use often to connect to the main ui. It happens both with chrome and edge. I also tried to clean cache but I am lways unable to see cards or badges. On the other hand, on my android devices and on my home windows 10 (home) PC the main ui shows almost every time the items regularly (rarely a refresh is necessary). Is this behavior possibly related to the issue being described here?
EDIT: if I connect to MyopenHAB (i.e remotely) the mainUI always shows the cards contents in the PC in which it doesn’t work locally.
