Hello everybody,
I’m encountering problems with my 2.1.0 version of OpenHAB.
I installed it from the archive downloaded from OpenHAB.org, on an OrangePI2+ computer. Decompressed it in /opt/openhab-2.1.0. Created a symlink /opt/openhab-runtime that is linked to /opt/openhab-2.1.0
I followed instructions to setup OpenHAB as a service (created a file openhab2.service in /lib/systemd/system as shown in the documentation for manual installation on linux. I adapted the text of this file, setting all paths to /opt/openhab-runtime).
The service is correctly set up and it starts/stops fine. Openhab2 starts automatically at every reboot.
For some reason, I updated the operating system of my OrangePI+ and restarted it the 12th of August.
OpenHab started well once again, but my logs don’t move since this date. More problematic, the little rule I set up for warm water heating (switching on or off three electric water heater threw 3 KNX switches) isn’t working anymore.
I didn’t see any technical problem on the OrangePi+ (no I/O error, no disk usage problem).
I can’t connect to Karaf console because it doesn’t seem to be launched by the way I’m starting OpenHAB.
Any help would be appreciated.
Thanks in advance.
