- Platform information:
- Hardware: RPI3+, rf gateway on Arduino Mega, Sonoff (Tasmota) Gateway
- OS: openhabian
- openHAB version: last
- Issue of the topic: after some time stops updating Items values
Newly reinstalled system works more than half of Year. Openhabian I use long time with different RPI’s.
This summer I did different changes with system Items and Things, converting to mqtt binding v.2.
Last month oftenly (1-2 times/day) I got my system stop working till I restart it.
OS is working, mosquitto too, web is accessible, log show no new messages except cromecast access to Home Mini. HabPanel show all my pages and I can press buttons, but pressing not change button values. Measurements and graphics are freeze and show last values. Stop happened at different time and do not depends on rules or anything what I can found.
I connect to karaf and try to change Items by command:
openhab> smarthome:status BathRoomHumidityTresh
64
openhab> smarthome:send BathRoomHumidityTresh 100
Command has been sent successfully.
64
This value was not sent to mqtt.
[10:22:16] openhabian@openhab:/var/log$ /usr/sbin/service openhab2 status
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2019-10-12 20:52:11 EEST; 14h ago
Main PID: 560 (java)
Tasks: 156 (limit: 2319)
Memory: 369.4M
CGroup: /system.slice/openhab2.service
560 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib
Oct 12 20:52:11 openhab systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 12 20:53:24 openhab karaf[560]: Loading class com.mysql.jdbc.Driver'. This is deprecated. The new driver class is
com.mysql.cj.jdbc.Driver’. The driver is automat
After I restart openhab service, Item manipulation make possible and new values are showing in WEB.
Strange, but I can’t access mysql. On sudo mysql command I got:
mysql: relocation error: mysql: symbol stdi.mysql_real_connect@mysql_list_tables_start version GLIBC_2.4 not defined in file libc.so.6 with link time reference
Have any Idea what happened and where to look for problems?
