After the update to 2.4 FGK 101
after the update to 2.4 two window sensors Fibaro FGK101 do not react anymore.
in the Paper Ui are the online.aber if I press the I see in the log no reaction. Have already debug turned on but these two nodes do not appear there.should I stop something? Everything worked well before the update. I’ve already installed 2.5 Binding but it still does not work. All other Fibaro Actors work normally
Those are battery devices, after upgrading wake them up manually a couple of times. Also make sure you have set your association group to the controller.
I have a little bit of running now there are some info in the log that are NODE 33 and NODE 24
`2019-02-24 16:28:30.725 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Controller status changed to ONLINE.
2019-02-24 16:28:30.730 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Controller is ONLINE. Starting device initialisation.
2019-02-24 16:28:30.727 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:sensor_door linked - polling started.
2019-02-24 16:28:30.730 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:battery-level linked - polling started.
2019-02-24 16:28:30.735 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_co2 linked - polling started.
2019-02-24 16:28:30.735 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_smoke linked - polling started.
2019-02-24 16:28:30.731 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_flood linked - polling started.
2019-02-24 16:28:30.739 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_heat linked - polling started.
2019-02-24 16:28:30.739 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_general linked - polling started.
2019-02-24 16:28:30.740 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:sensor_temperature2 linked - polling started.
2019-02-24 16:28:30.733 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_co linked - polling started.
2019-02-24 16:28:30.759 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Updating node properties.
2019-02-24 16:28:30.763 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Updating node properties. MAN=2147483647
2019-02-24 16:28:30.765 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Properties synchronised
2019-02-24 16:28:30.868 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2019-02-24 16:28:30.870 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising Thing Node…
2019-02-24 16:28:30.873 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:2339266f:node33:sensor_door for OpenClosedType
2019-02-24 16:28:30.875 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:sensor_door for OpenClosedType
2019-02-24 16:28:30.878 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:sensor_door for OpenClosedType
2019-02-24 16:28:30.880 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:2339266f:node33:battery-level for PercentType
2019-02-24 16:28:30.883 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:battery-level for PercentType
2019-02-24 16:28:30.885 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:2339266f:node33:alarm_flood for OnOffType
2019-02-24 16:28:30.887 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:alarm_flood for OnOffType
2019-02-24 16:28:30.890 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:2339266f:node33:alarm_co for OnOffType
2019-02-24 16:28:30.892 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:alarm_co for OnOffType
2019-02-24 16:28:30.894 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:2339266f:node33:alarm_smoke for OnOffType
2019-02-24 16:28:30.896 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:alarm_smoke for OnOffType
2019-02-24 16:28:30.898 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:2339266f:node33:alarm_co2 for OnOffType
2019-02-24 16:28:30.900 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:alarm_co2 for OnOffType
2019-02-24 16:28:30.902 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:2339266f:node33:alarm_general for OnOffType
2019-02-24 16:28:30.904 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:alarm_general for OnOffType
2019-02-24 16:28:30.907 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:2339266f:node33:alarm_heat for OnOffType
2019-02-24 16:28:30.909 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:alarm_heat for OnOffType
2019-02-24 16:28:30.911 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:2339266f:node33:sensor_temperature2 for QuantityType
2019-02-24 16:28:30.913 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:sensor_temperature2 for QuantityType
2019-02-24 16:28:30.915 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:2339266f:node33:sensor_temperature2 for QuantityType
2019-02-24 16:28:30.917 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Polling intialised at 86400 seconds - start in 22982400 milliseconds.
2019-02-24 16:28:30.919 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Device initialisation complete.
2019-02-24 16:28:33.239 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 13 06 31 05 03 0A 00 00 DF
2019-02-24 16:28:33.250 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=19, callback=0, payload=00 13 06 31 05 03 0A 00 00
2019-02-24 16:28:33.255 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=19, callback=0, payload=00 13 06 31 05 03 0A 00 00
2019-02-24 16:28:33.259 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-24 16:42:32.559 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:sensor_door unlinked - polling stopped.
2019-02-24 16:42:32.559 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:sensor_door linked - polling started.
2019-02-24 16:42:37.558 [INFO ] [org.quartz.core.QuartzScheduler ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
2019-02-24 16:43:08.243 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 18 02 84 07 6A
2019-02-24 18:45:40.896 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Handler disposed. Unregistering listener.
2019-02-24 18:45:40.926 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 33: Serialise aborted as static stages not complete
019-02-24 18:47:53.745 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:sensor_door linked - polling started.
2019-02-24 18:47:53.742 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 29: Channel zwave:device:2339266f:node29:alarm_motion linked - polling started.
2019-02-24 18:47:53.748 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=374, service.bundleid=191, service.scope=singleton} - org.openhab.binding.zwave
2019-02-24 18:47:53.749 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:battery-level linked - polling started.
2019-02-24 18:47:53.751 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_co linked - polling started.
2019-02-24 18:47:53.751 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_flood linked - polling started.
2019-02-24 18:47:53.752 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_smoke linked - polling started.
2019-02-24 18:47:53.754 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_heat linked - polling started.
2019-02-24 18:47:53.754 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:sensor_temperature2 linked - polling started.
2019-02-24 18:47:53.754 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_general linked - polling started.
2019-02-24 18:47:53.752 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Channel zwave:device:2339266f:node33:alarm_co2 linked - polling started.
2019-02-24 18:47:53.775 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}
2019-02-24 18:48:00.083 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 33: Serializing from file /var/lib/openhab2/zwave/network_d8c8e900__node_33.xml
2019-02-24 18:48:00.100 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 33: Error serializing from file: file does not exist.
2019-02-24 18:48:00.254 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 33: Starting initialisation from EMPTYNODE
2019-02-24 18:48:00.254 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Starting initialisation from EMPTYNODE
2019-02-24 18:48:00.256 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 27: Starting initialisation from EMPTYNODE
2019-02-24 18:48:00.256 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 21: Starting initialisation from EMPTYNODE
2019-02-24 18:48:00.269 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Starting initialisation from EMPTYNODE
2019-02-24 18:48:00.284 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 1: Restore from config: Ok.
2019-02-24 18:48:00.289 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 33: Init node thread finished
2019-02-24 18:48:00.294 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 33: Node advancer - advancing to IDENTIFY_NODE
2019-02-24 18:48:00.306 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 33: Node advancer: Initialisation starting
2019-02-24 18:48:02.791 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: ProtocolInfo
2019-02-24 18:48:02.792 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Listening = false
2019-02-24 18:48:02.794 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Routing = true
2019-02-24 18:48:02.795 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Beaming = true
2019-02-24 18:48:02.796 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Version = 4
2019-02-24 18:48:02.797 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: FLIRS = false
2019-02-24 18:48:02.799 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Security = false
2019-02-24 18:48:02.801 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Max Baud = 40000
2019-02-24 18:48:02.802 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Basic = BASIC_TYPE_ROUTING_SLAVE
2019-02-24 18:48:02.804 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Generic = GENERIC_TYPE_SENSOR_BINARY
2019-02-24 18:48:02.805 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 33: Specific = SPECIFIC_TYPE_ROUTING_SENSOR_BINARY
2019-02-24 18:48:02.807 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2019-02-24 18:48:02.809 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2019-02-24 18:48:02.829 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Version = 1, version set. Enabling extra functionality.
2019-02-24 18:48:02.831 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2019-02-24 18:48:02.832 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Creating new instance of command class COMMAND_CLASS_BASIC
2019-02-24 18:48:02.834 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2019-02-24 18:48:02.836 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2019-02-24 18:48:02.837 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 12: Transaction COMPLETED
2019-02-24 18:48:15.398 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 24: Init node thread finished
2019-02-24 18:48:15.398 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 24: Node advancer - advancing to IDENTIFY_NODE
2019-02-24 18:48:15.400 [DEBUG] [ve.internal.protocol.ZWaveController] - Waiting for init thread Node_24_init
2019-02-24 18:48:15.400 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 24: Node advancer: Initialisation starting
2019-02-24 18:48:15.401 [DEBUG] [ve.internal.protocol.ZWaveController] - Init thread Node_24_init complete
2019-02-24 18:48:15.796 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Controller status changed to ONLINE.
2019-02-24 18:48:15.797 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2019-02-24 18:48:15.798 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising Thing Node…
2019-02-24 18:48:15.799 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:2339266f:node32:switch_binary for OnOffType
2019-02-24 18:48:15.801 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:2339266f:node32:switch_binary for OnOffType
2019-02-24 18:48:15.803 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:2339266f:node32:config_decimal_param7 for DecimalType
2019-02-24 18:48:15.804 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:2339266f:node32:config_decimal_param7 for DecimalType
2019-02-24 18:48:15.806 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:2339266f:node32:alarm_general for OnOffType
2019-02-24 18:48:15.807 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:2339266f:node32:alarm_general for OnOffType
2019-02-24 18:48:15.806 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Controller is ONLINE. Starting device initialisation.
2019-02-24 18:48:15.815 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating node properties.
2019-02-24 18:48:15.815 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:2339266f:node32:battery-level for PercentType
2019-02-24 18:48:15.816 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating node properties. MAN=271
2019-02-24 18:48:15.816 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Polling intialised at 1800 seconds - start in 1245600 milliseconds.
2019-02-24 18:48:15.818 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating node properties. MAN=271. SET. Was 271
2019-02-24 18:48:15.815 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 25: Controller is ONLINE. Starting device initialisation.
2019-02-24 18:48:15.821 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Properties synchronised
2019-02-24 18:48:15.823 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 25: Updating node properties.
2019-02-24 18:48:15.825 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 25: Updating node properties. MAN=271
2019-02-24 18:48:15.826 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 25: Updating node properties. MAN=271. SET. Was 271
2019-02-24 18:48:15.816 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 30: Initialising state channel zwave:device:2339266f:node30:switch_binary2 for OnOffType
2019-02-24 18:48:15.827 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 25: Properties synchronised
2019-02-24 18:48:15.823 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 29: Initialising state channel zwave:device:2339266f:node29:sensor_luminance for DecimalType
2019-02-24 18:48:15.829 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration synchronised
2019-02-24 18:48:16.207 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising Thing Node…
2019-02-24 18:48:16.207 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 32: Security = false
2019-02-24 18:48:16.208 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:2339266f:node24:scene_number for DecimalType
2019-02-24 18:48:16.210 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:2339266f:node24:scene_number for DecimalType
019-02-24 18:48:16.227 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:2339266f:node24:sensor_door for OpenClosedType
2019-02-24 18:48:16.239 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:2339266f:node24:battery-level for PercentType
2019-02-24 18:48:16.240 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:2339266f:node24:battery-level for PercentType
2019-02-24 18:48:16.243 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 32: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2019-02-24 18:48:16.242 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:2339266f:node24:alarm_co2 for OnOffType
2019-02-24 18:48:16.245 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:2339266f:node24:alarm_co2 for OnOffType
2019-02-24 18:48:16.245 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 22: Transaction COMPLETED
2019-02-24 18:48:16.246 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:2339266f:node24:alarm_general for OnOffType
2019-02-24 18:48:16.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 111ms
2019-02-24 18:48:16.247 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:2339266f:node24:alarm_general for OnOffType
2019-02-24 18:48:16.249 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:2339266f:node24:alarm_smoke for OnOffType
2019-02-24 18:48:16.249 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 22: Transaction completed
2019-02-24 18:48:16.250 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:2339266f:node24:alarm_smoke for OnOffType
2019-02-24 18:48:16.251 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:22 DONE
2019-02-24 18:48:16.251 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:2339266f:node24:sensor_door1 for OpenClosedType
2019-02-24 18:48:16.276 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-24 18:48:16.275 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:2339266f:node24:sensor_door1 for OpenClosedType
2019-02-24 18:48:16.275 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 22: Transaction event listener: DONE: DONE ->
2019-02-24 18:48:16.290 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:2339266f:node24:sensor_temperature2 for QuantityType
2019-02-24 18:48:16.291 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:2339266f:node24:sensor_temperature2 for QuantityType
2019-02-24 18:48:16.293 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Polling intialised at 86400 seconds - start in 21772800 milliseconds.
2019-02-24 18:48:16.294 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Device initialisation complete.
2019-02-24 18:48:16.296 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 32: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@c2bfea
2019-02-24 18:48:16.288 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-24 18:48:16.297 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 32: Node Init transaction completed with response COMPLETE
2019-02-24 18:48:16.301 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 32: Node advancer - advancing to REQUEST_NIF
2019-02-24 18:48:16.302 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2019-02-24 18:48:16.299 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 41 1D A7
2019-02-24 18:48:16.306 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 41 1D A7
2019-02-24 18:48:16.309 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT`
I have activated several times and association group is controller.
Association Groups
1: Input IN1
Controller
