Hello Guys.
After uninstalling the HabMin UI (got the problem that i can’t install bindings, comes with an error at HabPanel, see )
I can’t install HabPanel again, it isn’t listed in the PaperUI any more? The experminetal is enabled…
No one has a fix for this? Pretty annoying that I can’t install it
Also if I put it in the conf that it should install as a UI - simply says can’t find the HabPanel
