After Upgrade Add-ons from Marketplace missing
Dear all,
after an Upgrade to 4.3.5-1 my add-ons from the marketplace are not installed and i have to install them. Sometimes its also when i have to reboot my system.
Version:     4.3.5 (Build)
User:        openhab (Active Process 1702388)
User Groups: openhab tty dialout audio
Directories: Folder Name      | Path                        | User:Group
             OPENHAB_HOME     | /usr/share/openhab          | openhab:openhab
             OPENHAB_RUNTIME  | /usr/share/openhab/runtime  | openhab:openhab
             OPENHAB_USERDATA | /var/lib/openhab            | openhab:openhab
             OPENHAB_CONF     | /etc/openhab                | openhab:openhab
             OPENHAB_LOGDIR   | /var/log/openhab            | openhab:openhab
             OPENHAB_BACKUPS  | /var/lib/openhab/backups    | openhab:openhab
These are the two Add-ons:
320 │ Active │  80 │ 3.3.0.202207031140    │ openHAB Add-ons :: Bundles :: Synology Surveillance Station Bi
321 │ Active │  80 │ 4.0.0.SNAPSHOT        │ ConnectorIO - Addons - UI - Iconify
Does someone have the same issue or could hep me to find out the reason?
Regards
Simon
The reason is that there is no way for OH to know if the installed add-ons are compatible with the new version of OH and if they are not it can cause OH to fail to come up entirely.
Therefore after an upgrade, for now, you have to reinstall add-ons from the marketplace manually, where available.
Many thanks, for the reply so it is working as needed :slight_smile:
