Hi all,
I just upgraded from OH 2.5 to 3 using openhabian-config. I had no errors during the upgrade process. However, I cannot access the UI and my app can’t connect to OH either.
I searched the forum and found similar reports but none of the suggested tipps work for me.
sudo systemctl status openhab results in:
openhab.service - openHAB instance, reachable at http://openHABianDevice:8080
Loaded: loaded (/usr/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: active (running) since Fri 2021-04-23 14:44:06 CEST; 1min 46s ago
Docs: Introduction | openHAB
https://community.openhab.org
Main PID: 4815 (java)
Tasks: 30 (limit: 2062)
CGroup: /system.slice/openhab.service
└─4815 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab
Apr 23 14:44:06 openHABianDevice systemd[1]: Started openHAB instance, reachable at http://openHABianDevice:8080.
…skipping…
● openhab.service - openHAB instance, reachable at http://openHABianDevice:8080
└─override.conf
I tried to change the port but it didn’t help. “Fix permissions” results in an error. But I can’t find out why.
Did anyone experience a similar behaviour? Any solutions? If you need more information please let me know.
Best, Max
