after upgrade using apt-get my openhab not start.
help to start it on!
sudo /bin/systemctl status openhab2.service -l
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: active (running) since Сб 2018-06-09 21:28:00 MSK; 12min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 4030 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 4274 (java)
CGroup: /system.slice/openhab2.service
└─4274 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dfelix.cm.dir=/var/lib/openhab2/config -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dorg.ops4j.pax.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyAMA0 -Djava.endorsed.dirs=/opt/jdk1.8.0_131/jre/lib/endorsed:/opt/jdk1.8.0_131/lib/endorsed:/usr/share/openhab2/runtime/lib/endorsed -Djava.ext.dirs=/opt/jdk1.8.0_131/jre/lib/ext:/opt/jdk1.8.0_131/lib/ext:/usr/share/openhab2/runtime/lib/ext -Dkaraf.instances=/var/lib/openhab2/tmp/instances -Dkaraf.home=/usr/share/openhab2/runtime -Dkaraf.base=/var/lib/openhab2 -Dkaraf.data=/var/lib/openhab2 -Dkaraf.etc=/var/lib/openhab2/etc -Dkaraf.logs=/var/log/openhab2 -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab2/tmp -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab2/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.1.5.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.jaas.boot-4.1.5.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.main-4.1.5.jar:/usr/share/openhab2/runtime/lib/boot/org.osgi.core-6.0.0.jar org.apache.karaf.main.Mainиюн 09 21:36:12 raspberrypi karaf[4274]: 21:36:12.193 [pool-53-thread-1] ERROR org.openhab.core.karaf.internal.FeatureInstaller - Failed installing ‘openhab-binding-http1, openhab-binding-exec, openhab-misc-openhabcloud, openhab-binding-network, openhab-ui-habpanel, openhab-binding-zwave, openhab-binding-onewire1, openhab-binding-networkupstools1, openhab-persistence-rrd4j, openhab-ui-basic, openhab-ui-classic, openhab-binding-ntp, openhab-ui-habmin, openhab-binding-systeminfo, openhab-ui-paper’: Error:
июн 09 21:36:12 raspberrypi karaf[4274]: Resource mvn:org.openhab.persistence/org.openhab.persistence.rrd4j/1.12.0 does not contain a manifest
июн 09 21:37:12 raspberrypi karaf[4274]: 21:37:12.189 [pool-55-thread-1] ERROR org.openhab.core.karaf.internal.FeatureInstaller - Failed installing ‘openhab-binding-http1, openhab-binding-exec, openhab-misc-openhabcloud, openhab-binding-network, openhab-ui-habpanel, openhab-binding-zwave, openhab-binding-onewire1, openhab-binding-networkupstools1, openhab-persistence-rrd4j, openhab-ui-basic, openhab-ui-classic, openhab-binding-ntp, openhab-ui-habmin, openhab-binding-systeminfo, openhab-ui-paper’: Error:
июн 09 21:37:12 raspberrypi karaf[4274]: Resource mvn:org.openhab.persistence/org.openhab.persistence.rrd4j/1.12.0 does not contain a manifest
июн 09 21:38:12 raspberrypi karaf[4274]: 21:38:12.183 [pool-57-thread-1] ERROR org.openhab.core.karaf.internal.FeatureInstaller - Failed installing ‘openhab-binding-http1, openhab-binding-exec, openhab-misc-openhabcloud, openhab-binding-network, openhab-ui-habpanel, openhab-binding-zwave, openhab-binding-onewire1, openhab-binding-networkupstools1, openhab-persistence-rrd4j, openhab-ui-basic, openhab-ui-classic, openhab-binding-ntp, openhab-ui-habmin, openhab-binding-systeminfo, openhab-ui-paper’: Error:
июн 09 21:38:12 raspberrypi karaf[4274]: Resource mvn:org.openhab.persistence/org.openhab.persistence.rrd4j/1.12.0 does not contain a manifest
июн 09 21:39:12 raspberrypi karaf[4274]: 21:39:12.156 [pool-59-thread-1] ERROR org.openhab.core.karaf.internal.FeatureInstaller - Failed installing ‘openhab-binding-http1, openhab-binding-exec, openhab-misc-openhabcloud, openhab-binding-network, openhab-ui-habpanel, openhab-binding-zwave, openhab-binding-onewire1, openhab-binding-networkupstools1, openhab-persistence-rrd4j, openhab-ui-basic, openhab-ui-classic, openhab-binding-ntp, openhab-ui-habmin, openhab-binding-systeminfo, openhab-ui-paper’: Error:
июн 09 21:39:12 raspberrypi karaf[4274]: Resource mvn:org.openhab.persistence/org.openhab.persistence.rrd4j/1.12.0 does not contain a manifest
июн 09 21:40:12 raspberrypi karaf[4274]: 21:40:12.177 [pool-61-thread-1] ERROR org.openhab.core.karaf.internal.FeatureInstaller - Failed installing ‘openhab-binding-http1, openhab-binding-exec, openhab-misc-openhabcloud, openhab-binding-network, openhab-ui-habpanel, openhab-binding-zwave, openhab-binding-onewire1, openhab-binding-networkupstools1, openhab-persistence-rrd4j, openhab-ui-basic, openhab-ui-classic, openhab-binding-ntp, openhab-ui-habmin, openhab-binding-systeminfo, openhab-ui-paper’: Error:
июн 09 21:40:12 raspberrypi karaf[4274]: Resource mvn:org.openhab.persistence/org.openhab.persistence.rrd4j/1.12.0 does not contain a manifest
