Thank you for your quick response, @wborn.
Contents of /etc/openhab2/services/addons.cfg
# The installation package of this openHAB instance
# Note: This is only regarded at the VERY FIRST START of openHAB
# Note: If you want to specify your add-ons yourself through entries below, set the package to "minimal"
# as otherwise your definition might be in conflict with what the installation package defines.
# Optional. If not set, the dashboard (https://<yourserver>:8080/) will ask you to choose a package.
# Valid options:
# - minimal : Installation only with dashboard, but no UIs or other add-ons. Use this for custom setups.
# - simple : Setup for using openHAB purely through UIs - you need to expect MANY constraints in functionality!
# - standard : Default setup for normal users, best for textual setup
# - expert : Setup for expert users, especially for people migrating from openHAB 1.x
# - demo : A demo setup which includes UIs, a few bindings, config files etc.
# See https://www.openhab.org/docs/configuration/packages.html for a detailed explanation of these packages.
package = minimal
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required for the installation of
# any legacy 1.x add-on. (default is true)
remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation of 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (default is false)
legacy = true
# A comma-separated list of bindings to install (e.g. "binding = sonos,knx,zwave")
binding = amazonechocontrol,astro1,chromecast,expire1,googletts,hue,kodi,lutron,mqtt1,ntp,tradfri,unifi,weather1,yamahareceiver,zigbee,zwave
# A comma-separated list of UIs to install (e.g. "ui = basic,paper")
ui = basic,classic,paper,habpanel,habmin
# A comma-separated list of persistence services to install (e.g. "persistence = rrd4j,jpa")
persistence = mapdb,rrd4j,gcal
# A comma-separated list of actions to install (e.g. "action = mail,pushover")
#action =
# A comma-separated list of transformation services to install (e.g. "transformation = map,jsonpath")
transformation = jsonpath,map,regex
# A comma-separated list of voice services to install (e.g. "voice = marytts,freetts")
voice = googletts
# A comma-separated list of miscellaneous services to install (e.g. "misc = myopenhab")
misc = gcal1,restdocs,hueemulation,ruleengine
# Surprise, the new authentication DOES NOT WORK!
org.eclipse.smarthome.auth:authentication.enabled="false"
Contents of /var/lib/openhab2/config/org/openhab/addons.config
binding="amazonechocontrol,astro1,chromecast,expire1,googletts,hue,kodi,lutron,mqtt1,ntp,tradfri,unifi,weather1,yamahareceiver,zigbee,zwave"
legacy="true"
misc="gcal1,restdocs,hueemulation,ruleengine"
package="minimal"
persistence="mapdb,rrd4j,gcal"
remote="true"
service.pid="org.openhab.addons"
transformation="jsonpath,map,regex"
ui="basic,classic,paper,habpanel,habmin"
voice="googletts"
I have set the DEBUG log level for org.openhab.core.karaf and will report here with any further details gleaned from the log.
