After upgrade to OH4 following error
After upgrade to open OH4 following errors are in the log file.
What is the reason for these log entries?
2023-07-29 12:13:38.289 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘knx_write_4_3_1’ failed: org.graalvm.polyglot.PolyglotException: TypeError: Cannot read property “toOpenHabString” from undefined
2023-07-29 12:13:42.084 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
at ._toOpenhabString(@openhab-globals.js:2) ~[?:?]
at .postUpdate(@openhab-globals.js:2) ~[?:?]
at .:program(:6) ~[?:?]
at org.graalvm.polyglot.Context.eval(Context.java:399) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:458) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:426) ~[?:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:262) ~[java.scripting:?]
at org.openhab.automation.jsscripting.internal.scriptengine.DelegatingScriptEngineWithInvocableAndAutocloseable.eval(DelegatingScriptEngineWithInvocableAndAutocloseable.java:53) ~[?:?]
at org.openhab.automation.jsscripting.internal.scriptengine.InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.eval(InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.java:78) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:71) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:178) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:68) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1188) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:997) ~[?:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:87) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
Seems you have a UI Rule with uid knx_write_4_3_1 which has some issues. Maybe it will suffice to open the rule and save it.
If not: What is the purpose of the rule? how does it look like?
Please keep in mind, that all text copied from openHAB should be marked as code in the forum, because otherwise the forum software will change some text without asking for permission :slight_smile:
This is a new created rule, an exact copy from a migrated rule. I think this is another Problem.
Can you paste the rule causing this stack trace?
Hello Lauren, sorry I am back to 3.4.5, so I only have the rule in 3.4.5. It was also a Problem with shelly i3. Thank you for your support.
