May I ask if there is a solution for this problem meanwhile?
I’m on the upgrade form OH 2.3 to 2.5M1 with KNX1 but my log file is spammed with hundreds of entries like that:
2019-06-16 11:09:00.440 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '30336.0' could not be sent to the KNX bus using datapoint 'command DP 4/2/17 Sicherung_F0y_El_Verbrauch, DPT main 0 id 13.013, low priority' - retrying one time: 13.013 Active energy in kWh: wrong value format: 30336.0
2019-06-16 11:09:00.440 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '30336.0' could not be sent to the KNX bus using datapoint 'command DP 4/2/17 Sicherung_F0y_El_Verbrauch, DPT main 0 id 13.013, low priority' - giving up after second try: 13.013 Active energy in kWh: wrong value format: 30336.0
2019-06-16 11:09:00.491 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '36741.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/10 Sicherung_F10_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 36741.0
2019-06-16 11:09:00.491 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '36741.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/10 Sicherung_F10_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 36741.0
2019-06-16 11:09:00.543 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/10 Sicherung_F10_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.543 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/10 Sicherung_F10_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.594 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/10 Sicherung_F10_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.595 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/10 Sicherung_F10_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.646 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/11 Sicherung_F11_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.646 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/11 Sicherung_F11_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.697 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/11 Sicherung_F11_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.698 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/11 Sicherung_F11_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.749 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/11 Sicherung_F11_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.749 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/11 Sicherung_F11_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.806 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/12 Sicherung_F12_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.806 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '36742.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/12 Sicherung_F12_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 36742.0
2019-06-16 11:09:00.853 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '33078.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/13 Sicherung_F13_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 33078.0
2019-06-16 11:09:00.853 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '33078.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/13 Sicherung_F13_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 33078.0
2019-06-16 11:09:00.907 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '33078.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/13 Sicherung_F13_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 33078.0
2019-06-16 11:09:00.907 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '33078.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/13 Sicherung_F13_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 33078.0
2019-06-16 11:09:00.987 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '36741.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/14 Sicherung_F14_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 36741.0
2019-06-16 11:09:00.989 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '36741.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/14 Sicherung_F14_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 36741.0
2019-06-16 11:09:01.029 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '36737.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/15 Sicherung_F15_Betriebsstunden, DPT main 0 id 7.007, low priority' - retrying one time: 7.007 Time period in hours: wrong value format: 36737.0
2019-06-16 11:09:01.029 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '36737.0' could not be sent to the KNX bus using datapoint 'command DP 4/0/15 Sicherung_F15_Betriebsstunden, DPT main 0 id 7.007, low priority' - giving up after second try: 7.007 Time period in hours: wrong value format: 36737.0
Any advise?
Thanks & regards
John
