Hi All
I have for some time struggled with getting my AHC 9000 (Jablotron AC-116) connected to Openhab and tried for some time to use it directly with a Modbus (RS485 Serial interface) directly connected to the Openhab system running on a Raspberry Pi, but without luck…
So i tried another way… by going via MQTT… By searching on the web i found that DKJonas had made a code and a schematic for making a ESP8266 connected to a AHC9000 and thus create a MQTT interface over Wifi… a HUGE Thanks goes out to DKJonas for this
So here is my recepie for how to connect the dots so to speak (aka getting AHC 9000 to speak to OpenHAB 3 and vice versa)
Just to be clear i did try to setup the MQTT Things, Items and Bridge by using the GUI on OH3 but to be Honest it is simply NOT intuitive to me and i found my self running arround in loops trying to figure out what i should do,
and somehow the code that DKJonas made or the OpenHAB system is not making the auto detection part very good and the GUI doe NOT give you very good feedback on when thins go wrong.
So i switched to goo old Configuration Texting with support from Frontail to provide me feedback on when OH3 did not like what i was doing
You might have better luck than me in this department…
Prerequisites:
- OpenHAB 3 system up and running (I use a Raspberry Pi 3B+ where OH3 is installed on a Raspbian platform so i can access the unit via VNC but thats just me liking to do other stuff with the RPI byond having OH# on it)
Materials you need:
- 1 pcs of ESP8266 module pr AHC 9000 you which to connect to OpenHAB
- 1pcs of UART to RS485 converter (MAX3072 or MAX485 or … There are many devices out there with same pinout and functionality. Just Remember they have to be 3.3V compliant)
- 1 pcs of 24V to 3.3V SMPS (I used a TRACO TRSN 1-2433 but again you may find many similar Buck converters out there so just something that can convert 24V to 3.3V)
- 1 pcs. of Ethernet cable (take an old cable and cut off 10 cm, you only need the one end and plug of the cable
- 1 pcs of Veoboard
- Some wires to solder to the Veo-Board
- Pin-headers with 2.54mm spacing will help
- A soldering iron
First of all go visit the github page made by DKJonas and download the Arduino code and Schematic
GitHub - dkjonas/Wavin-AHC-9000-mqtt: Esp8266 mqtt interface for Wavin AHC-9000/Jablotron AC-116 -
Buy parts mentioned above and assemble the Schematic by using the Veo-board and wire (and possible the pin headers as you then can replace the parts after building the main board) See my attached picture (i know this could be done i a more Professional way by making a PCB but Veo Board has to do for now
Download DK JonasCode onto ESP8266 by either using the Arduino Programming tool or VS Code (I used VS Code and Platform IO
Getting Started with VS Code and PlatformIO IDE for ESP32 and ESP8266 | Random Nerd Tutorials -
Attach the ESP8266 “Module” to your AHC 90000
Open up Openhabian-config via SSH or VNC or directly on the OS
Under “Optional Components” Install the “Mosquitto broker” and exit the openhabian-config
Note: You are probably ased to enter a username and Password for the Mosquitto Broker (remember it as youre going to use it later on) -
Go into OpenHAB 3 Openhab-conf folders (mus be accessible via Samba Server or similar)
Go into the Things Folder and make a file called mqtt.things (or whatever you like but ended with .things)
Open this file and put the following into it
Bridge mqtt:broker:OpenHAB_MQTT_Broker “MQTT Broker in Basement” [
host=“127.0.0.1”,
secure=false,
port=1883,
qos=0,
retain=false,
clientid=“OH3MqttClient”,
keep_alive_time=30000,
reconnect_time=60000,
// Here you are going to use the Username and password for the MQTT Broker
username=“openhabian”,
password=“password”
Thing topic AHC_9000_Base “AHC9000 in Basement” {
Channels:
Type number : Temperature_0 “Temperature_0” [
// floorE8DB8493ED31 = floor+MAC addr of ESP8266 device
stateTopic=“heat/floorE8DB8493ED31/0/current”
Type number : Setpoint_0 “Setpoint_0” [
stateTopic=“heat/floorE8DB8493ED31/0/target”,
commandTopic=“heat/floorE8DB8493ED31/0/target_set”
Type number : Battlvl_0 “Battlvl_0” [
stateTopic=“heat/floorE8DB8493ED31/0/battery”
Type switch : Solenoid_0 “Solenoid_0” [
stateTopic=“heat/floorE8DB8493ED31/0/output”,
on=“on”,
off=“off”
]Type number : Temperature_1 "Temperature_1" [ stateTopic="heat/floorE8DB8493ED31/1/current" ] Type number : Setpoint_1 "Setpoint_1" [ stateTopic="heat/floorE8DB8493ED31/1/target", commandTopic="heat/floorE8DB8493ED31/1/target_set" ] Type number : Battlvl_1 "Battlvl_1" [ stateTopic="heat/floorE8DB8493ED31/1/battery" ] Type switch : Solenoid_1 "Solenoid_1" [ stateTopic="heat/floorE8DB8493ED31/1/output", on="on", off="off" ] // Repeat the above with as many Channels you have (i.e. rooms) and just replace the 0 with a 1,2,3,4 etc.
- Go into the Items Folder and make a file called mqtt.items (or whatever you like but ended with .items)
Group Basement “Kælder” (Home)
//*** MQTT items *********************************************************************************************************************************************/
// ItemType itemName [“label text”] [] [(group1, group2, …)] [{bindingconfig-statetopic, bindingconfig-commandtopic}]
Number Temperature_0 “Temperatur [%.1f C]” (Basement) { channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Temperature_0” }
Number Setpoint_0 “Setpoint [%.1f C]” (Basement) { channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Setpoint_0”, channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Setpoint_0” }
Number Battlvl_0 “Batt level [%.0f %%]” (Basement) { channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Battlvl_0” }
Switch Output_0 “Solenoid” (Basement) { channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Solenoid_0” }
Number Temperature_1 “Temperatur [%.1f C]” (Basement) { channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Temperature_1” }
Number Setpoint_1 “Setpoint [%.1f C]” (Basement) { channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Setpoint_1”, channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Setpoint_1” }
Number Battlvl_1 “Batt level [%.0f %%]” (Basement) { channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Battlvl_1” }
Switch Output_1 “Solenoid” (Basement) { channel=“mqtt:topic:OpenHAB_MQTT_Broker:AHC_9000_Base:Solenoid_1” }
Go into the Sitemaps Folder and make a file called mqtt.sitemaps (or whatever you like but ended with .sitemaps)
sitemap Test label=“TEST OH3” {
Frame label=“Hoved side” {
Group item=Basement icon=“cellar” {
Frame label=“Toilet” {
Text item=Temperature_0
Text item=Battlvl_0
Selection item=Setpoint_0 mappings=[15=15C, 16=16C,17=17C, 18=18C, 19=19C, 20=20C, 21=21C, 22=22C, 23=23C, 24=24C]
Switch item=Output_0
Frame label=“Værelse 4 (Cykel rum)” {
Text item=Temperature_1
Text item=Battlvl_1
Selection item=Setpoint_1 mappings=[15=15C, 16=16C,17=17C, 18=18C, 19=19C, 20=20C, 21=21C, 22=22C, 23=23C, 24=24C]
Switch item=Output_1
Go into the Rules Folder and make a file called mqtt.rules (or whatever you like but ended with .rules)
rule “Setpoint_0 Selector”
Item Setpoint_0 received update
switch (Setpoint_0) {
case 15: Setpoint_0.sendCommand(15)
case 16: Setpoint_0.sendCommand(16)
case 17: Setpoint_0.sendCommand(17)
case 18: Setpoint_0.sendCommand(18)
case 19: Setpoint_0.sendCommand(19)
case 20: Setpoint_0.sendCommand(20)
case 21: Setpoint_0.sendCommand(21)
case 22: Setpoint_0.sendCommand(22)
case 23: Setpoint_0.sendCommand(23)
case 24: Setpoint_0.sendCommand(24)
rule “Setpoint_1 Selector”
Item Setpoint_1 received update
switch (Setpoint_1) {
case 15: Setpoint_1.sendCommand(15)
case 16: Setpoint_1.sendCommand(16)
case 17: Setpoint_1.sendCommand(17)
case 18: Setpoint_1.sendCommand(18)
case 19: Setpoint_1.sendCommand(19)
case 20: Setpoint_1.sendCommand(20)
case 21: Setpoint_1.sendCommand(21)
case 22: Setpoint_1.sendCommand(22)
case 23: Setpoint_1.sendCommand(23)
case 24: Setpoint_1.sendCommand(24)
And voila you should now have a setup where you can read each room temperature, setpoint, battery level and if the solenoid is ON and thus heat is flowing to your room
Hope this helps other out there so you wont have to struggle as much as i did…
BR
MKlitgaard
