rkrisi
(Kristof Rado)
April 12, 2018, 4:12pm
#1
Does anybody uses this binding or knows what is the problem? Sometimes it works for fine, sometimes not… and it is very unstable when it works or not. Usually for hours, but sometimes works for just 5-10 minutes and after that doesn’t work for hours.
The error what I get:
[airquality.handler.AirQualityHandler] - Error in aqicn.org (Air Quality) response: missing data sub-object
idkpmiller
(Paul Miller)
April 13, 2018, 11:28pm
#2
I am seeing the same issue recently too.
Is ee the two lines below in my log.
LOGS
2018-04-14 11:21:20.425 [WARN ] [airquality.handler.AirQualityHandler] - Error in aqicn.org (Air Quality) response: missing data sub-object
2018-04-14 11:21:20.435 [hingStatusInfoChangedEvent] - 'airquality:aqi:home' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): missing data sub-object
marker
(Martin)
April 14, 2018, 8:24am
#3
same issue here:
happens since the last update with openhabian-config.
rkrisi
(Kristof Rado)
April 15, 2018, 8:16pm
#4
This will be solved in the next update?
vzorglub
(Vincent Regaud)
April 15, 2018, 9:37pm
#6
You will need to raise an issue on Github.
ariela
(Andrea Riela)
April 17, 2018, 4:20pm
#7
same issue here.
Did you raise the issue on Github? can you please share the link for reference?
thanks
Andrea
rkrisi
(Kristof Rado)
April 17, 2018, 5:56pm
#8
Here you’ll find the issue on Github.
