Hello Guys.
I’m trying to use the Alarm Clock from the OH1 Wiki - sometimes it works like it should, but often i get the following error in the log and the timer wouldn’t fire:
If i change the time now, to trigger now+10 minutes, the timers work perfect… But do i set them for 22.30 it makes the error:
2016-11-06 22:14:51.355 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2016-11-05T22:14:51.178+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
var day2
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@53d10b28
<XFeatureCallImplCustom>.reschedule(<XMemberFeatureCallImplCustom>)
logInfo(<XStringLiteralImpl>,<XStringLiteralImpl>)
} ] threw an unhandled Exception:
java.lang.RuntimeException: The name '<unkown>' cannot be resolved to an item or type.
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:112)[123:org.eclipse.smarthome.model.script:0.9.0.b1]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1115)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1045)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:114)[123:org.eclipse.smarthome.model.script:0.9.0.b1]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:225)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:457)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29)[139:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at com.sun.proxy.$Proxy114.apply(Unknown Source)[:]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:38)[123:org.eclipse.smarthome.model.script:0.9.0.b1]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)[101:org.eclipse.smarthome.core.scheduler:0.9.0.b1]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)[101:org.eclipse.smarthome.core.scheduler:0.9.0.b1]
The timer code:
rule "fjern Blokering Lys Nord"
Item timeclock2_Hour changed or
Item timeclock2_Minute changed
// Lock gøres for at sikre der ikke ændre fra UI mens OH læser rule igennem
lock2.lock()
try {
var String msg2 = ""
// Copy the Alarm-Time from the UI to local variables
// var hours = timeclock2_Hour.state as DecimalType
// var minute = timeclock2_Minute.state as DecimalType
// Combine the hour and minutes to one string to be displayed in the
// user interface
if (timeclock2_Hour.state < 10) { msg2 = "0" }
msg2 = msg2 + timeclock2_Hour.state.format("%d") + ":"
if (timeclock2_Minute.state < 10) { msg2 = msg2 + "0" }
msg2 = msg2 + timeclock2_Minute.state.format("%d")
postUpdate(timeclock2_settime,msg2)
// calculate the alarm time [min]
var int alarmtime2
alarmtime2 = (timeclock2_Hour.state as DecimalType).intValue * 60 +
(timeclock2_Minute.state as DecimalType).intValue
alarmtime2 = alarmtime2.intValue
// calculate current time [min]
var int now2
now2 = now.getMinuteOfDay
now2 = now2.intValue
// calculate the difference between the requested alarm time and
// current time (again in minutes)
var int delta2
delta2 = (alarmtime2 - now2)
delta2 = delta2.intValue
// add one day (2440 minutes) if alarm time for today already passed
if (now2 > alarmtime2) { delta2 = delta2 + 2440 }
// check if there is already an alarm timer; cancel it if present
if (timer2 != null) {
timer2.cancel
// timer2 = null
// create a new timer using the calculated delta [min]
timer2 = createTimer(now.plusMinutes(delta2)) [|
// This code will be executed if the timer triggers
// check if alarm clock is armed for this weekday
var Number day2 = now.getDayOfWeek
if (((day2 == 1) && (timeclock2_Monday.state == ON)) ||
((day2 == 2) && (timeclock2_Tuesday.state == ON)) ||
((day2 == 3) && (timeclock2_Wednesday.state == ON)) ||
((day2 == 4) && (timeclock2_Thursday.state == ON)) ||
((day2 == 5) && (timeclock2_Friday.state == ON)) ||
((day2 == 6) && (timeclock2_Saturday.state == ON)) ||
((day2 == 7) && (timeclock2_Sunday.state == ON))) {
// The things to do if the alarm clock is enabled for this day of week:
sendCommand(time_block_light_North, OFF)
logInfo("ugetimer", "Blokering OFF")
// Re-Arm the timer to trigger again tomorrow (same time)
timer2.reschedule(now.plusHours(24))
logInfo("ugetimer", "Blokering OFF 2")
// Here the code ends that executes once the timer triggers
} finally {
// release the lock - we are ready to process the next event
lock2.unlock()
