Alarm Decoder Binding Question with zwave lock
Does the alarm decoder binding give you information about zwave devices? I have a zwave shclage door lock connected to a vista 20p. I want to be notified when the door lock is locked by the keypad.
I know I could re-register the lock to the openhab system but I was hoping to avoid that.
thanks
Brad
Sorry I can’t help you but I was wondering how you connect a Zwave lock to your Vista 20p. I have the same alarm panel and a Zwave lock.
I am using the alarm.com communicator with built in zwave. Somehow the
communicator passed the signal that the keypad was used to unlock the door
so it should also unarm the system
I did not know is all that logic is housed in alarm.com or locally.
