Hi
I’m trying to tidy this up - this works but there must be an easier way!
7 day alarm clock code using this
var Timer timerPerson1Alarm = null
rule "Person1 preset load"
Item Person1_Alarm_Presets received command
var int sollMinute
var int sollHour
var int RunTime
switch (Person1_Alarm_Presets.state){
//early shift
case 1:{
sollHour=6
sollMinute=30
RunTime=60
//late shift
case 2:{
sollHour=8
sollMinute=30
RunTime=60
//set hour,Minute,runtime items for each day
var i = 0
var TheDay= "NA"
//don't change saturday/sunday. set i max=7 and uncomment cases if you have to work weekends, you unlucky soul
while ((i=i+1) <= 7) {
switch i{
case 1: TheDay = "Mo"
case 2: TheDay = "Tu"
case 3: TheDay= "We"
case 4: TheDay= "Th"
case 5: TheDay= "Fr"
case 6: TheDay= "Sa"
case 7: TheDay= "Su"
//set all hours
gPerson1Alarm.members.filter(s|s.name == "Person1_Alarm_"+TheDay+"_H").forEach[s | s.postUpdate(sollHour)]
//set all Minutes
gPerson1Alarm.members.filter(s|s.name == "Person1_Alarm_"+TheDay+"_M").forEach[s | s.postUpdate(sollMinute)]
//set runtimes
gPerson1Alarm.members.filter(s|s.name == "Person1_Alarm_"+TheDay+"_RUN").forEach[s | s.postUpdate(RunTime)]
Trying to conotate the time into a single string to display - and ultimately display tomorrow’s time on alarm clock openhab panel
rule "update Mo Alarm"
Item Person1_Alarm_Mo_H changed or
Item Person1_Alarm_Mo_M changed
Person1_Alarm_Mo_T.postUpdate((Person1_Alarm_Mo_H.state.toString) + ":" + (String.format("%02d", (Person1_Alarm_Mo_M.state as Number).intValue)))
x7 ie 1 for each day of the week!
I’ve tried simply putting the conotated expression into a separate expression
gPerson1Alarm.members.filter(s|s.name == "Person1_Alarm_"+TheDay+"_T").forEach[s | s.postUpdate((Person1_Alarm_Mo_H.state.toString) + ":" + (String.format("%02d", (Person1_Alarm_Mo_M.state as Number).intValue)))]
I’ve also tried making each part a variav=ble and doing - but it doesnt work
Help appreciated
