The ZWAVE Binding by @chris is very stable. I’ve been using it for years now. Also, just to let you know, you can actually add this zwave bridge to Vista20P if you also already have their RF Keypad. I have it and I only use it to lock my zwave doors. That way, locks are still automated even if OH is down for any reason.
G’morning… Ah, the auto update makes total sense now (continuing to learn here).The z-wave bridge is a great idea, no RF here though - strictly wired only. I was adamant about it when the house was built. Chris was super helpful when I needed to add support for these Fibaro wall plugs and its been solid so far. I’ll move forward this weekend with pairing more sensors to the z-wave system.
I initially thought of wired sensors for the system, and almost did. The thing about wireless is you can take it with you when you move to a diff house.
The wires, of course not. But everything else you can, My big sister bought a house and they took everything that wasn’t structural so to speak. Seriously, towel racks, toilet paper dispensers… Everything. True story.
I see you discuss AlarmDecoder here and I have a question - I bought Alarm Panel Focus FC-7640 - 8 wired and 32 wireless zone + GSM SIM and TCP/IP connectivity - they say it’s Ademco protocol based. Can this binding for AlarmDecoder can be used or no worth wasting time. I did some tries, but maybe don’t create the Thing properly and also missing how to configure it in alarmdecoder config file.
Telnet connection on port 80 is not giving any feedback - just connects and stays black window.
Any advises are appreciated.
Apologizes that I’ve jumped your your conversation.
Lucky -
This is great stuff you are sharing. I am quite excited to have OH and the my trusty crusty Vista-20 connected. I’m very happy to use the alarm and also determine presence for now. I had posted earlier that I was having an issue but edited the post because the issue was mearly a typo. Stopped for a while and listened to some nice Blues music and it was easy to sport.
Later maybe if we both leave the the alarm becomes the slave to the presence detection. If anyone has experience with this I’m all ears
The v2 version of this binding (if it ever gets accepted) has a “sendStar” setting which sends the “*” character to the panel after it is disarmed. In the v1 binding you would have to set up a rule to do this.
After the “*” character is sent to the Vista, it will begin to update the zone field as you trip the zones. When zone is updated the Ready status is cleared. So something like
rule “presence”
Item StatusReady changed to 0
switch (Zone.state)
case 7:
do stuff for zone 7
Good to hear there is a version 2. I’m having fun with what I’ve got and trying to learn to write rules. I would be interested to know if the version 2 is available to try. Some of my other projects are coming along and may try to keep going at least a little bit through the summer months
So I had this working with my old 2.5 install and version 1 of the binding but for the life of me I cannot get it to work with openhab3 and the latest binding. Is ser2sock still needed/required ?.
In fronttail I am not seeing any messages being parsed. If i arm and disarm through the keypad I am seeing log events but none while using habpanel. Can someone please post an items/things or atleast point me in the right direction.
You need to connect the bridge via tty or a port, and if using a port then you still need ser2sock or ser2net. Attached is the thing and items for my vista20-se, with the old v1.x binding format commented out so you can see the difference. There is also doc on the addon page.
Thanks for the info.My bridge is attached to /dev/ttyUSB0 so I guess I still need ser2sock.Actually what do you mean by port? I will look over your files to see if there are any clues to solving this.
I do presume my bridge is working since I am getting rfzones flooding my inbox. I have since turned off discovery. I am also getting log line when I arm/disarm open/close zones from my keypad.
Hi actually my server crashed and I took that opportunity to try out Home Assistant. So almost 2 years now I haven’t looked back….but all not lost …yet…Ill take a look to see if I can if I still have my openhab back up available to have a look.
You can send keypad commands via the channel ‘command’ (send as a string). If you are disarming the system using this, I recommend adding an expire to the channel so that it masks the code you just sent. I’ve provided a sample of the item (*.items) below. I hope this helps.
I am not sure how to translate between text configuration and GUI configuration, but over the next week or so I will experiment and post back what I tried and the results.
I currently only configure ‘things’ and ‘items’ via a file (my preference), so I can’t comment on the UI. AD things define the bridge, keypad and zones via their address and channels. The command channel is only defined within items (file).
