Alexa answer "Es gibt mehrere Geräte mit diesem Namen"
  • Platform information:
    • Hardware: Synology DS204+
    • Java Runtime Environment: Synology Java 8.0.151-0014
    • openHAB version: 2.2.0.007-SNAPSHOT
I need help in according with Alexa. Since christmas we have our first Echo and so we start with our first experience.
Fort he beginning we implemated only switches/lights. Here are an example:
Switch AVM_WZ_TiLampe       "Wohnzimmer Tischlampe"     		<light>            (LichtInnen) [ "Switchable" ]       {channel="avmfritz:FRITZ_DECT_200:192_168_178_1:xxxxxxxx:outlet"}
Switch AVM_WZ_StLampe       "Wohnzimmer Stehlampe"      		<light>            (LichtInnen) [ "Switchable" ]       {channel="avmfritz:FRITZ_DECT_200:192_168_178_1: xxxxxxxx:outlet"}
Switch EGWZ_Dunstabzug      "Kueche Dunstabzug"                 <switch>           (Steuerung)  [ "Switchable" ]       {channel="homematic:HMIP-PSM:ccu2:xxxxxxxxx:3#STATE"}
Dimmer WZ_Dimmer            "Weihnachtsstern"	                <light>            (Licht, LichtInnen, Weihn) ["Lighting"]    {channel="homematic:HmIP-PDT:ccu2: xxxxxxxx:3#LEVEL"}
For our surprise ist works. If we say „Alexa Wohnzimmer Stehlampe ein“ or „Weihnachtsstern auf 50%“ Alexa sends the instruction to openhab successfull.
The next step was to integrate the Homematic Thermostat (Homematic 132030 Funk-Wandthermostat).
Here the item-settings:
Group gEGWZ_TC             "Wohnzimmer Thermostat"                                                           ["Thermostat"]
Number  EGWZ_TC_TempIst    "Wohnzimmer Temperatur Ist [%.1f °C]"      <temperature>   (KlimaEG,gEGWZ_TC)     ["CurrentTemperature"]            {channel="homematic:HM-TC-IT-WM-W-EU:ccu2: xxxxxxxx:2#ACTUAL_TEMPERATURE"}
Number  EGWZ_TC_TempSoll   "Wohnzimmer Temperatur Soll [%.1f °C]"     <temperature>   (gEGWZ_TC)             ["TargetTemperature"]             {channel="homematic:HM-TC-IT-WM-W-EU:ccu2: xxxxxxxx:2#SET_TEMPERATURE"}
String  EGWZ_TC_CtrlM      "Wohnzimmer Heizungsmodus"                 <radiator>                             ["homekit:HeatingCoolingMode"]    {channel="homematic:HM-TC-IT-WM-W-EU:ccu2: xxxxxxxx:2#CONTROL_MODE"}
This works as well with the follwing instruction „Alexa setzte Wohnzimmer Temperatur auf 21 Grad“
But with a second Thermostat an the adding of the following items, Alexa get a problem. Here the list of the items:
Group   gEGArb_TC          "Arbeit Thermostat"        ["Thermostat"]
Number  EGArb_TC_TempIst   "Arbeit Temperatur Ist [%.1f °C]"                 <temperature>    (KlimaEG,gEGArb_TC)   ["CurrentTemperature"]            {channel="homematic:HM-TC-IT-WM-W-EU:ccu2: xxxxxxxx:1#TEMPERATURE"}
Number  EGArb_TC_TempSoll  "Arbeit Temperatur Soll [%.1f °C]"                <temperature>    (gEGArb_TC)           ["TargetTemperature"]             {channel="homematic:HM-TC-IT-WM-W-EU:ccu2: xxxxxxxx:2#SET_TEMPERATURE"}
String  EGArb_TC_CtrlM     "Arbeit Heizungsmodus"                            <radiator>       (gEGArb_TC)           ["homekit:HeatingCoolingMode"]    {channel="homematic:HM-TC-IT-WM-W-EU:ccu2: xxxxxxxx:2#CONTROL_MODE"}
She cant find the items. For the instruction “Alex, setze Wohnzimmer Temperatur aus 20 Grad” she Answer „Es gibt mehrere Geräte mit diesem Namen“.
Can someone explain me so that’s how it is
Shouldn’t it be „Alexa setze Wohnzimmer Temperatur Soll auf 21 Grad“?
(I don’t own an Alexa system, just a guess)
