after the last upgrade to 2.5.10 of the Alexa Binding the texttospeech item has now a beep before any tts message. In the past it works without the beep. What I understood is that the beep is only for an announcement but not for texttospeech function. Any idea how I can disable the beep ?
That seems to be the item that you use as input to be sent to Alexa. What I meant is the TTS channel.
Just in case it could be defined in a different way.
Mine is defined as:
String Echo_Living_Room_TTS "Text to Speech" (Alexa_Living_Room) {channel="amazonechocontrol:echo:xxxxxxxx:XXXXXXXXXXXXXXXX:textToSpeech"}
All thinks and items are defined by Paper UI. Only things which are not supported directly I add manually.
In the REST interface it looks :
"linkedItems": [
"ShowWohnzimmer_Sprich"
"uid": "amazonechocontrol:echoshow:xxxxxxxx:xxxxxxxxxxxxxxx:textToSpeech",
"id": "textToSpeech",
"channelTypeUID": "amazonechocontrol:textToSpeech",
"itemType": "String",
"kind": "STATE",
"label": "Sprich",
"description": "Spricht den Text (Nur schreiben). Es kann reiner Text oder SSML verwendet werden: e.g. <speak>Ich will dir ein Geheimnis erzählen.<amazon:effect name=\"whispered\">Ich bin nicht wirklich ein Mensch.</amazon:effect></speak>",
"defaultTags": [],
"properties": {},
"configuration": {}
looks from my end fine…
one remark before you ask, Beep is diabled on Amazon Echo Settings.
The reason was that I set the volume to a standard value before I send the message. The beep comes from the setting command and in result the message delay was to long for me. Now I remove the setvolume for the Alexa devices and it works without beep. Thanks again
best, Christian
