Hallo,
Alexa somehow doesn’t find all the items here my home. items
Switch server "SchackSchack" ["Switchable"] { wol="192.168.178.255#d0:50:99:19:7c:bb" }
Group gBadThermostat "Bad Thermostat" ["Thermostat"]
Number BadThermostatTargetTemperature "Bad Thermostat Soll Temperatur" (gBadThermostat) [ "TargetTemperature" ] {channel="max:thermostat:KMD1055827:KMD3069582:set_temp"}
Number BadThermostatCurrentTemp "Bad Thermostat Aktuelle Temperatur" (gBadThermostat) [ "CurrentTemperature" ] {channel="max:thermostat:KMD1055827:KMD3069582:actual_temp"}
Group gStubeThermostat "Stube Thermostat" ["Thermostat"]
Number StubeThermostatTargetTemperature "Stube Thermostat Soll Temperatur" (gStubeThermostat) [ "TargetTemperature" ] {channel="max:thermostat:KMD1055827:KMD3066852:set_temp"}
Number StubeThermostatCurrentTemp "Stube Thermostat Aktuelle Temperatur" (gStubeThermostat) [ "CurrentTemperature" ] {channel="max:thermostat:KMD1055827:KMD3066852:actual_temp"}
Group gKuecheThermostat "Kueche Thermostat" ["Thermostat"]
Number KuecheThermostatTargetTemperature "Küche Thermostat Soll Temperatur" (gKuecheThermostat) [ "TargetTemperature" ] {channel="max:thermostat:KMD1055827:LEQ1149210:set_temp"}
Number KuecheThermostatCurrentTemp "Küche Thermostat Aktuelle Temperatur" (gKuecheThermostat) [ "CurrentTemperature" ] {channel="max:thermostat:KMD1055827:LEQ1149210:actual_temp"}
Group gSchlafzimmerThermostat "Schlafzimmer Thermostat" ["Thermostat"]
Number SchlafzimmerThermostatTargetTemperature "Schlafzimmer Thermostat Soll Temperatur" (gSchlafzimmerThermostat) [ "TargetTemperature" ] {channel="max:thermostat:KMD1055827:KEQ0407098:set_temp"}
Number SchlafzimmerThermostatCurrentTemp "Schlafzimmer Thermostat Aktuelle Temperatur" (gSchlafzimmerThermostat) [ "CurrentTemperature" ] {channel="max:thermostat:KMD1055827:KEQ0407098:actual_temp"}
Switch goodnight "good night" ["Switchable"]
Switch heizungan "heizung an" ["Switchable"]
Switch allelichteraus "alle Licher aus" ["Switchable"]
Switch away "Alles Aus" ["Switchable"]
Switch TabFlur [ "Switchable" ] { http=">[ON:POST:http://192.168.178.45:2323/?cmd=screenOn&password=test] >[OFF:POST:http://192.168.178.45:2323/?cmd=screenOff&password=test]" }
Switch test "test" ["Switchable"]
Switch Luftreiniger "Luftreiniger" ["Switchable"] {channel="miio:basic:0403DB23:power"}
Switch lichtgateway "Licht Gateway" ["Switchable"] {channel="mihome:gateway:7811dcaf2714:brightness"}
The last 6 items are not found, all the others are there and work.
Does anyone have an idea or recognizes a mistake?
