Hi Team,
as soon. as I add items for a second or third echo device I receive error messages while viewing the PaperUI Control.
Platform information:
Hardware: Raspberry Pi 3B+
OS: OpenHabianPi
Java Runtime Environment: from OpenHabianPi
openHAB version: 2.4.0.1
Issue of the topic: Error Message as soon as more than one echo device is configured
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
Linux openHABianPi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Mar 27 09:53:56 2019 from 192.168.1.129
2019-03-29 16:46:57,483: FireMotD: Info: No FireMotD ExportFile detected. Please generate with “sudo ./FireMotD -S”
[17:05:36] root@openHABianPi:/var/log/openhab2# vi openhab.log
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: org.openhab.binding.amazonechocontrol.internal.HttpException: GET url ‘https://alexa.amazon.de/api/behaviors/entities?skillId=amzn1.ask.1p.music’ failed: Bad Request **
** at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:549) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:407) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getMusicProviders(Connection.java:1256) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.statedescription.AmazonEchoDynamicStateDescriptionProvider.getStateDescription(AmazonEchoDynamicStateDescriptionProvider.java:248) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelStateDescriptionProvider.getDynamicStateDescription(ChannelStateDescriptionProvider.java:132) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelStateDescriptionProvider.getStateDescription(ChannelStateDescriptionProvider.java:118) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelStateDescriptionProvider.getStateDescriptionFragment(ChannelStateDescriptionProvider.java:80) ~[?:?]
at org.eclipse.smarthome.core.internal.service.StateDescriptionServiceImpl.mergeStateDescriptionFragments(StateDescriptionServiceImpl.java:104) ~[?:?]
at org.eclipse.smarthome.core.internal.service.StateDescriptionServiceImpl.getStateDescription(StateDescriptionServiceImpl.java:90) ~[?:?]
at org.eclipse.smarthome.core.items.GenericItem.getStateDescription(GenericItem.java:399) ~[?:?]
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.considerTransformation(EnrichedItemDTOMapper.java:110) ~[?:?]
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:62) ~[?:?]
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:56) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.item.ItemResource.lambda$0(ItemResource.java:238) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:?]
at java.util.HashMap$KeySpliterator.tryAdvance(HashMap.java:1574) ~[?:?]
at java.util.stream.StreamSpliterators$WrappingSpliterator.lambda$initPartialTraversalState$0(StreamSpliterators.java:294) ~[?:?]
at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.fillBuffer(StreamSpliterators.java:206) ~[?:?]
at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.doAdvance(StreamSpliterators.java:169) ~[?:?]
at java.util.stream.StreamSpliterators$WrappingSpliterator.tryAdvance(StreamSpliterators.java:300) ~[?:?]
at java.util.Spliterators$1Adapter.hasNext(Spliterators.java:681) ~[?:?]
at org.eclipse.smarthome.io.rest.Stream2JSONInputStream.fillBuffer(Stream2JSONInputStream.java:94) ~[?:?]
at org.eclipse.smarthome.io.rest.Stream2JSONInputStream.read(Stream2JSONInputStream.java:70) ~[?:?]
Hi Michael,
I tested the 2.5(6) Beta. (renamed it as … 2.4.0.jar and created a new sha1).
But I still get the sitemap error:
HTTP ERROR 500
Problem accessing /basicui/app. Reason:
Server Error
Caused by:
at org.eclipse.smarthome.core.items.GenericItem.getStateDescription(GenericItem.java:393)
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:338)
at org.eclipse.smarthome.ui.basic.internal.render.AbstractWidgetRenderer.preprocessSnippet(AbstractWidgetRenderer.java:121)
at org.eclipse.smarthome.ui.basic.internal.render.SelectionRenderer.renderWidget(SelectionRenderer.java:76)
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:194)
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:160)
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:181)
at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:124)
at org.eclipse.smarthome.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:189)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.Server.handle(Server.java:531)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
at java.lang.Thread.run(Thread.java:748)
Powered by Jetty:// 9.4.11.v20180605
I reduced the .items entries to a minimum and got rid of the error message.
While testing I observed that the “echo” is e.g. not showing the bluetoothMAC while the echospot do show the Mac-address of the connected bluetooth device in PaperUI.
// Bluetooth
String Echo_Kueche_BluetoothMAC “Kueche Bluetooth MAC Address” (Alexa_Kueche) {channel=“amazonechocontrol:echo:d9b9966d:G090ST0274460JSJ:bluetoothMAC”}
Switch Echo_Kueche_Bluetooth “Kueche Bluetooth” (Alexa_Kueche) {channel=“amazonechocontrol:echo:d9b9966d:G090ST0274460JSJ:bluetooth”}
String Echo_Kueche_BluetoothDeviceName “Kueche Bluetooth Device” (Alexa_Kueche) {channel=“amazonechocontrol:echo:d9b9966d:G090ST0274460JSJ:bluetoothDeviceName”}
Please mark the topic solved by clicking the square box on the post that provided the solution and edit the title to start with [Solved]. This will hopefully help others with a similar situation find a quick solution.
