is there any way to set-up my garage door to be able say “open garage door” instead of “garage door on”? If I tell alexa to open the garage door, she says that device doesn’t support that. I configured it as switchable.
You could change that directly in the Alexa app if you simply create a routine and adding your garage door switch to it. In the Routine you can decide wich sentence you want to use.
As you highlighted in the post below, asset ids (friendlyNames="@Setting.Opening") should not be translated opposed to standard text-based labels (friendlyNames="Garagentor"). The reason is because the former translates to all supported languages on the Alexa side. This is why it usually recommended to use these over standard labels.
