Alexa Smart Home Skill V3 is now live!
Since the v3 update Alexa has not been able to find any new devices. I left it for a couple of days since the upgrade, but always got Device is not responding. So, I essentially removed all the configuration and linking of Alexa to Openhab Cloud and removing the tags and trying the v3 style - but to no avail. I am running on Release 2.4.
Examples from my items.config
Number  FridgeTemperature "Fridge Temperature  [%.1f °C]" <temperature>   ["CurrentTemperature"]        { alexa="TemperatureSensor.temperature" [scale="Celsius"], channel="mihome:sensor_ht:158d00012cc0ba:temperature" }
Dimmer  LoungeDimmer    "ZWave Dimmer [%d %%]"  <slider> (All,AllLights) {  alexa="PowerController.powerState,BrightnessController.brightness",channel="zwave:device:8617eeea:node7:switch_dimmer" }
Perhaps a syntax error? I have 125 items and some of them are image items.
Although I do get many of the these messages below when triggering a discovery from the Alexa app:
2019-08-17 17:12:52.207 [WARN ] [thome.io.rest.internal.DTOMapperImpl] - Field 'editable' could not be eliminated: Can not set boolean field org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTO.editable to null value
and it’s always no new devices found for awhile after that.
My recommendation for 2.4 users is to use the release candidate version of the binding from here. It works fine with 2.4 installations. Or of course, the 2.5 M2 includes the same version out of the box.
will this version be included in OH 2.4 Release version soon?
Because I would like to avoid manual installation of non released components
No. There are never changes to the stable builds.
This is exactly what I discribed before. Ok, it seems all users are getting this.
Actually they went normally again in my app.
All items shows now the correct state.
The only thing I did was: going to sleep :upside_down_face:
I have been adding some new thermostat upper and lower items, see below for two examples. I would like to test them, but I am not sure what to say to Alexa to get the values set, can you advise?
Number BR1_Max_Temp 	"BR1 Max Temperature" 				(gBR1_Temp, statepersist, gRoundup_1, gTempMax)		{ alexa="ThermostatController.upperSetpoint" }
Number BR1_Min_Temp 	"BR Min Temperature" 				(gBR1_Temp, statepersist, gRoundup_1, gTempMin)		{ alexa="ThermostatController.lowerSetpoint" }
Paul
i’m out of my home i’ll Try as soon as I came back home
For the moment (accessing remotely) same as before devices not responding…
Is there any way to use the old v2 skill that was perfect for me?
I can confirm this. And I also went to sleep… :smiley:
Thanks for the response.
When will the 2.5 version of OH will be released?
No idea.
Hi, sorry for the delayed response, I did the following today 17/08/2019 :
10:11, “alexa turn on Heat recovery”
10:12, “alexa discover devices”
Many Thanks for looking into this.
So, I just switched to OH 2.5.0.M2.
But the Alexa commands are still not working. Still the same behaviour. Devices do not react and searching for new devices doesn’t find anything.
Do I have to do anything else?
I already restarted the system several times with no success.
Do the basic troubleshooting: make sure you have correct tags, check through REST Api if your item names are available.
Edit: disregard this one: “check through REST Api if your item names are available.” This was for the Amazon Echo Control binding :joy:
This Link: https://myopenhab.org/rest/items?metadata=alexa,channel,synonyms&recursive=true
provides me a valid JSON.
I can find my device:
{“link”:“https://myopenhab.org/rest/items/Sofa",“state”:“OFF”,“editable”:false,“type”:“Switch”,“name”:“Sofa”,“label”:“Sofa”,“tags”:[“Switchable”],"groupNames”:},
It’s called ‘Sofa’ (Couch) and is a simple switch.
So, it looks fine, right?
It used to work for the last months with this configuration, until the V3 skill has been released.
Same here and it still works, sorry. I did not use the new tagging, still on the old V2 tagging syntax.
Ok. Thanks for your help. Strange that it doesn’t work
Did you check if your cloud is online?
Shouldn’t it be a “Dimmer”?
Dimmer Innr_Light1_Temp "Licht Esszimmer1 ..." (GF_Eating, gInnr_Light1) [ "ColorTemperature" ] {channel="hue:0210:xxxxxx:5:color_temperature"}
Did you clear the cache after upgrading (although this should be done automatically if you did the upgrade according to the docs).
