I use Alexa to contol different things in my home and it works fine!
But I have a problem, when I want to control my Yamaha AV. When I say to Alexa “start radio x” Alexa thinks, she should play the radio. But what I want is alexa to start my yamaha av and to start network radio. Same problem, when i say “increase audio volume”. Alexa increases her own volume level, instead of the volume level of my yamaha av.
I think the problem is, that the openhab skill is not supporting “audio” commands.
The current skill is based on the Smarthome API’s of Amazon/Alexa. No audio controls are available.
As a workaround you could implement some virtual switches.
E.g. “network radio”. If you say “Alexa, turn on network radio” this switch is triggered.
Using a rule, you could turn on your Yahama AV and switch it to network radio. I don’t know if a binding exists for Yahama or you can control it using OpenHAB in some way, but there is a Yahama Receiver binding, so I guess that is covered.
Related to increase/decrease volume, you could follow a similar approach. But you would need to use some strange phrasing:
“Alexa, turn on Yahama volume increase” => would again trigger a virtual switch that increases the volume by e.g. 5%.
You can always consider building a custom Alexa skill. And I’ve read that Yahama has already foreseen Alexa integration for some of their receivers. Maybe you’re lucky.
Looks like this is supported now and a couple of people are working on it, https://github.com/openhab/openhab-alexa/issues/40. Are you aware of this and able to contribute. Sadly I’m not a Dev but wouldn’t love to be able to move it forward
