All bindings automatically uninstalled
I just added the lifx binding via the binding search in paper ui and the binding was installed. But after that there were pop-ups saying that all my other bindings were uninstalled.
This is the log:
10:08:24.579 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'lifx:colorlight:D073D5XXXXXX' to inbox.
10:08:24.878 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'lifx:colorlight:D073D5XXXXXX' to inbox.
10:08:24.880 [INFO ] [smarthome.event.InboxAddedEvent      ] - Discovery Result with UID 'lifx:colorlight:D073D5XXXXXX' has been added.
10:08:33.290 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:chromecast:XXXXXXXXXXXXXXXXXXXXXXXXXXXX' changed from ONLINE to UNINITIALIZED
10:08:33.297 [WARN ] [su.litvak.chromecast.api.v2.Channel  ] - Error while reading
java.net.SocketException: Socket closed
	at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?]
	at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) [?:?]
	at java.net.SocketInputStream.read(SocketInputStream.java:171) [?:?]
	at java.net.SocketInputStream.read(SocketInputStream.java:141) [?:?]
	at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) [?:?]
	at sun.security.ssl.InputRecord.read(InputRecord.java:503) [?:?]
	at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) [?:?]
	at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:940) [?:?]
	at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) [?:?]
	at sun.security.ssl.AppInputStream.read(AppInputStream.java:71) [?:?]
	at su.litvak.chromecast.api.v2.Channel.read(Channel.java:411) [203:org.openhab.binding.chromecast:2.2.0]
	at su.litvak.chromecast.api.v2.Channel.access$200(Channel.java:50) [203:org.openhab.binding.chromecast:2.2.0]
	at su.litvak.chromecast.api.v2.Channel$ReadThread.run(Channel.java:132) [203:org.openhab.binding.chromecast:2.2.0]
10:08:33.326 [WARN ] [su.litvak.chromecast.api.v2.Channel  ] - Error while reading
10:08:33.319 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:chromecast:XXXXXXXXXXXXXXXXXXXXXXXXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:33.469 [WARN ] [su.litvak.chromecast.api.v2.Channel  ] -  <--  null payload in message
10:08:33.428 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-chromecast'
10:08:33.394 [WARN ] [su.litvak.chromecast.api.v2.Channel  ] -  <--  null payload in message
10:08:33.488 [WARN ] [su.litvak.chromecast.api.v2.Channel  ] - Error while closing channel
10:08:33.482 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:audio:XXXXXXXXXXXXXXXXXXXXXXXXXXX' changed from ONLINE to UNINITIALIZED
10:08:33.510 [WARN ] [su.litvak.chromecast.api.v2.Channel  ] - Error while closing channel
10:08:33.610 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'chromecast:audio:XXXXXXXXXXXXXXXXXXXXXXXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:33.687 [INFO ] [smarthome.event.ExtensionEvent       ] - Extension 'binding-chromecast' has been uninstalled.
10:08:39.075 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from ONLINE to UNINITIALIZED
10:08:39.103 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:39.134 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from ONLINE to UNINITIALIZED
10:08:39.146 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:39.167 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-wifiled'
10:08:39.186 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from ONLINE to UNINITIALIZED
10:08:39.199 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:ACCF23XXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:39.214 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:F0FE6BXXXXXX' changed from ONLINE to UNINITIALIZED
10:08:39.228 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'wifiled:wifiled:F0FE6BXXXXXX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:39.242 [INFO ] [smarthome.event.ExtensionEvent       ] - Extension 'binding-wifiled' has been uninstalled.
10:08:47.763 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:50-f5-da-XX-XX-XX' changed from INITIALIZING to UNINITIALIZED
10:08:48.172 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:50-f5-da-XX-XX-XX' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:08:56.598 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-amazondashbutton'
10:08:56.610 [INFO ] [smarthome.event.ExtensionEvent       ] - Extension 'binding-amazondashbutton' has been uninstalled.
10:09:03.026 [INFO ] [smarthome.event.ItemStateChangedEvent] - jeelink_lacrosse_21_temperature changed from 4.8 to 4.9
10:09:03.037 [INFO ] [smarthome.event.ItemStateChangedEvent] - Temperature_Outdoor changed from 4.8 to 4.9
10:09:03.692 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-dmx'
10:09:03.708 [INFO ] [smarthome.event.ExtensionEvent       ] - Extension 'binding-dmx' has been uninstalled.
10:09:10.980 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:lacrosse:3' changed from ONLINE to UNINITIALIZED
10:09:11.005 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:lacrosse:3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:11.018 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:lacrosse:21' changed from ONLINE to UNINITIALIZED
10:09:11.028 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:lacrosse:21' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:11.041 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:xxxxxxxx' changed from ONLINE to UNINITIALIZED
10:09:11.093 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'jeelink:jeelinkUsb:xxxxxxxx' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:11.139 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-jeelink'
10:09:11.150 [INFO ] [smarthome.event.ExtensionEvent       ] - Extension 'binding-jeelink' has been uninstalled.
10:09:18.493 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:xxxxxxxx:node2' changed from ONLINE to UNINITIALIZED
10:09:18.678 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:xxxxxxxx:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:18.712 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:xxxxxxxx:node3' changed from ONLINE to UNINITIALIZED
10:09:18.787 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:device:xxxxxxxx:node3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:18.803 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:xxxxxxxx' changed from ONLINE to UNINITIALIZED
10:09:21.894 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
10:09:21.928 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'zwave:serial_zstick:xxxxxxxx' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
10:09:22.016 [INFO ] [.core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-binding-zwave'
10:09:22.027 [INFO ] [smarthome.event.ExtensionEvent       ] - Extension 'binding-zwave' has been uninstalled.
Can someone tell me why this might happened?
see Bindings are uninstalling autonomously (no solution, but same problem)
see also Bindings being auto-uninstalled?
I am having the same problem. I thought it was with my RPI-3 and Openhabian, so I installed OpenHab2 on a Linux (Ubuntu) system. It looked good last night, then this morning I went to bindings and my Insteon binding was missing even tho it was there last night. To make it even more confusing, I go to Add-Ons - Bindings. Scroll down to InsteonPLM Binding and it shows that it is installed.
I did not have this problem with the Openhab system that I setup last fall, but lost that hardware. Now setting up this new system from scratch, having this frustration over and over again.
Same Problem here - Openhabian on Raspberrypi, installed WeMo binding and all other bindings auto uninstalled. Things were goiing well before that too.
i am in as well … tried deleting the .cfg’s in the service folder so far …
There’s been a Distro issue opened for this. Please go post information there, if you can:
I renamed both my items and sitemaps also just installed the minecraft binding (experiment) the system bailed and removed all bindings
OH 2.2.0 linux ubuntu
if any of that info helps (still have logs)
I am having the same issue, but it seams like that only the addons installed via paperui got uninstalled.
