Hello!
Here’s one for the books.
First the question: Do I need to re-install or is there another way to determine what else might have gone wrong and correct that without doing a complete apt-remove and purge before re-installing? I don’t mind doing that, it will give me a chance to correct some tiny ‘not best practice’ things I let slip in as I fiddled about with the technology - but would prefer not to as the wife is allready complaining she’s a coding widow (which she considers a downgrade from an astrophotography widow).
Running: Openhab 3.1.0, build 2433 (test distro, only just apt-updated this evening after being on the test distro) on a desktop computer with Ubuntu 20.04.2 LTS installed (GNU/Linux 5.4.0-74-generic x86_64). I also have subsonic, Homebridge, Apache2, Wordpress and Nextcloud installed on the same server…because you know, I like a simple life… 1TB SDD (78% used), 16GB RAM (4GB seems to be the general usage spot).
Everything was running as expected (which is to say not entirely a complete shamozzle as my programming is not top notch) and I decided to try out some tasmota functions and fiddle about with Sonoff 433mhz sensors (much faster on the ‘off’ update than zigbee or wi-fi). Probably should start with looking at z-wave before going down the path of 433mhz, but I digress.
After apt-updating, did a graceful shut down and re-boot, checked my openHAB status page and all the Things are listed as ‘Uninitialized’. After reading through the log, it told me that all of the bindings had ‘Failed installing’. Here’s what it looks like:
Log Extract
2021-06-23 16:18:25.867 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-binding-bluetooth, openhab-automation-pidcontroller, openhab-misc-openhabcloud, openhab-transformation-bin2json, openhab-binding-network, openhab-ui-habpanel, openhab-binding-lifx, openhab-automation-jsscripting, openhab-binding-zigbee, openhab-automation-pwm, openhab-binding-sensibo, openhab-binding-mqtt, openhab-transformation-map, openhab-binding-rfxcom, openhab-binding-lgwebos, openhab-binding-yeelight, openhab-binding-kodi, openhab-transformation-xslt, openhab-transformation-exec, openhab-transformation-jinja, openhab-transformation-scale, openhab-binding-upnpcontrol, openhab-binding-fronius, openhab-binding-milight, openhab-binding-ambientweather, openhab-binding-tplinksmarthome, openhab-transformation-javascript, openhab-binding-wemo, openhab-transformation-regex, openhab-binding-yamahareceiver, openhab-transformation-jsonpath, openhab-binding-zwave, openhab-automation-groovyscripting, openhab-binding-miio, openhab-binding-mihome, openhab-transformation-xpath, openhab-automation-jythonscripting, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-binding-openweathermap, openhab-binding-astro, openhab-binding-androiddebugbridge': Error:
Error downloading mvn:com.zsmartsystems.zigbee/com.zsmartsystems.zigbee.dongle.telegesis/1.4.0
Error downloading mvn:com.zsmartsystems.zigbee/com.zsmartsystems.zigbee.console.ember/1.4.0
Error downloading mvn:com.zsmartsystems.zigbee/com.zsmartsystems.zigbee.console/1.4.0
Error downloading mvn:com.zsmartsystems.zigbee/com.zsmartsystems.zigbee.dongle.xbee/1.4.0
Error downloading mvn:com.zsmartsystems.zigbee/com.zsmartsystems.zigbee.dongle.ember/1.4.0
Error downloading mvn:com.zsmartsystems.zigbee/com.zsmartsystems.zigbee/1.4.0
Error downloading mvn:com.zsmartsystems.zigbee/com.zsmartsystems.zigbee.console.telegesis/1.4.0
Error downloading mvn:com.zsmartsystems.zigbee/com.zsmartsystems.zigbee.dongle.cc2531/1.4.0
2021-06-23 16:19:25.430 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-binding-bluetooth, openhab-automation-pidcontroller, openhab-misc-openhabcloud, openhab-transformation-bin2json, openhab-binding-network, openhab-ui-habpanel, openhab-binding-lifx, openhab-automation-jsscripting, openhab-binding-zigbee, openhab-automation-pwm, openhab-binding-sensibo, openhab-binding-mqtt, openhab-transformation-map, openhab-binding-rfxcom, openhab-binding-lgwebos, openhab-binding-yeelight, openhab-binding-kodi, openhab-transformation-xslt, openhab-transformation-exec, openhab-transformation-jinja, openhab-transformation-scale, openhab-binding-upnpcontrol, openhab-binding-fronius, openhab-binding-milight, openhab-binding-ambientweather, openhab-binding-tplinksmarthome, openhab-transformation-javascript, openhab-binding-wemo, openhab-transformation-regex, openhab-binding-yamahareceiver, openhab-transformation-jsonpath, openhab-binding-zwave, openhab-automation-groovyscripting, openhab-binding-miio, openhab-binding-mihome, openhab-transformation-xpath, openhab-automation-jythonscripting, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-binding-openweathermap, openhab-binding-astro, openhab-binding-androiddebugbridge': Error:
So, after reading through it, it looks like something might be wrong with the Zigbee dongle (I use a HUSBZB-1, Nortek dongle as it handles both Zigbee and Z-wave). I removed the dongle, re-booted and no dice, same errors.
So, I have luckily backed up all my config files and rules, backed up all the sub-directories in conf and userdata. I’m not overly stressed about re-installing, just a little dissapointed if I have to.
Any advice on trouble-shooting?
